Hey folks, I've got a problem and getting mixed responses from local stores. Here is my situation -- I'm trying to get speakers installed in a main TV room, which will also have distributed audio (NuVo) to the room. i want to use in-walls for both the NuVo and use an automatic speaker selector to also use those two speakers as the rear left & right surrounds. I don't have good placement options for the fronts and center, so am considering a soundbar. I'll place a subwoofer separately in a corner of the room. I can run speaker cable from the AV closet to the soundbar as well as to the rear speakers, so I could get away with a non-powered soundbar correct? I've seen the Dayton LCR bar but wondering if there are other options or if this whole plan is going to create problems. If that is the case (it is a problem) I guess I'd go with a 5 channel soundbar and then just use the in-walls only for the distributed whole-house audio? Thanks in advance for your thoughts.
Cheers,
Matt
Cheers,
Matt
