AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Sony NSZ-GT1 with GOOGLE TV
Sony NSZ-GT1 with GOOGLE TV - Page 25
post #721 of 727
The one I received last week just said "general system stability". I haven't noticed any difference.
post #722 of 727
Anyone know if it is possible to have the Google Music app playing music while I am watching TV (ie. running the "TV app") on this device? For example, if I want to watch, say, a football game but have tunes playing from Google music. It works fine in the background for other functions but for obvious reasons, the music shuts off when I switch to TV viewing. I was hoping there was some way to do this.
post #723 of 727
I have been searching for an answer for this for awhile and havent had any luck so I decided to make this post.
Can I control a Denon receiver from the remote itself... without using IR blasters. All I want to do is be able to adjust the volume, which I can do just fine on my Samsung TV, but everything I see/read states I need to use the IR blaster for an AVR. I think I am stuck here but wanted to make sure no one knew of a workaround (denon volume control is the same code as sansui TVs for example) or if there was something I was missing. Thanks in advance
post #724 of 727
I'm having the same problem with reboots. Did you ever get it to stop?
post #725 of 727
Sony nsz-gt1 NOT recoginized as an input device to Hitachi 65 HD TV via HDMI cable
Hello All,
  I recently switched from DirectTV to basic cable and now my Sony nsz-gt1 Blue Ray Google device will NOT be recognized as an input to the TV.   I would just like to use the Blue Ray player to watch movies for now until we get ATT U-verse in a few months. The TV inputs allows for 5 inputs of all kinds (DVD1, DVD2, Camcorder3, AVR, etc..).   The Sony unit has 1 HDMI output and 1 HDMI input.  The TV only has 1 HDMI interface that works fine with other devices such PS3.   The Sony is NOT recognized by the TV.  I tried switching the HDMI cables to no avail. I reboot the device as well STILL not recognized by TV.  Please help.
Byron
post #726 of 727
Apart from making sure the HDMI cable isn't plugged into the HDMI input port on the back of the thing (it happens), if you've swapped out the cable and other devices are working just fine with both cables on the same set, then that's pretty much everything. You can probably try unplugging the GT1 from power entirely for about a minute or so, but if you're still not getting a picture at that point that probably wraps it up for that thing...
post #727 of 727
Originally Posted by byrontho View Post
Hello All,
Byron
Some TV's are proprietary and are finicky about what HDMI cable they will accept...eek.gif Also while you had Direct TV did you connect to the NSZ-GT1? If so you may want to call ATT U-Verse for support as their cable box needs to connect to the INPUT on the back of the NSZ and the output HDMI on the NSZ to your TV. You can usually hit home key on remote even if you do not have cable box on and you will be able to see the home shortcut screen...wink.gif Make sure that on back of NSZ output HDMI is connected to TV and input HDMI to cable box....wink.gif
http://esupport.sony.com/US/p/model-home.pl?mdl=NSZGT1&template_id=1&region_id=1&tab=tutorials#/tutorialsTab
