AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Subwoofer Wiring
Subwoofer Wiring
post #1 of 6
I have two 12'' pioneer subwoofers with a single 4ohm voice coil each, the max output of each sub is 1200watt. I have a mono-block amplifier rated to 2700watt max output at 4ohms.
how would I hook my subwoofers up so i dont blow a sub or my amp?
Detailed instructions please!
post #2 of 6
More details and specs needed including the amp's power ratings at 2 and 8 ohms.
post #3 of 6
If you wire the subs in parallel, it will make a 2 ohm load. If you wire them in series, it will make an 8 ohm load. Check you have an 8 ohm rating on the amp.
To wire in parallel, you connect the positive (+) from the amp to the + on both drivers. You can run two wires that are both connected to the amps + output or you can run a wire from the amp to sub1 then a wire from sub1 to sub2. Then do the same with the negative (-) side. Since your amp isn't rated for 2 ohms, I wouldn't recommend this.
To wire them in series, run a wire from the + on the amp to the + on sub1. Then run a wire from the - on sub1 to the + on sub2. Then run a wire from the - on sub2 to the - on the amp.
When you have more power available than the sub will take, you have to control the gain to keep from blowing the drivers.
post #4 of 6
2700 Watt Mono-Block Class-D Amplifier
1 x 2700 Watts Max Output
Fully Adjustable Electronic Crossover
Variable Bass Boost: (0-12dB @60Hz)
Soft Turn On/Off Circuit
2 Ohm Stable
Dual MOSFET PWM Power Supplies
Variable Gain Control
Remote Turn On
Heavy Duty Aluminum Alloy Heat Sink
Hi/Lo Level Molex Input
Power & Protection L.E.D
S/N Ratio: >95dB
Frequency Response: 40-150 Hz
THD: <0.04%
Fully Protected Circuitry
Dimensions: 11.1''W x 2.2''H x 13.9''L
Fuse: 25A x 2
Those are the full specs of the amplifier that i am given.
post #5 of 6
2 Ohm Stable
Remote Turn On
S/N Ratio: >95dB
THD: <0.04%
Fuse: 25A x 2
Not useful except for the disturbing FR spec.
post #6 of 6
What is the make and model of the amp?
