AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sony Internet TV (NSX-DDGT1) Thread
Official Sony Internet TV (NSX-DDGT1) Thread - Page 2
post #31 of 39
i plugged in the cnet settings....havent used the tv with a bluray yet just OTA HD and Standard Cable. basically same settings with a few tweaks sometimes i use warm 1.
Picture Mode Cinema
--Detailed settings sub-menu
Backlight: 5
Picture: 71
Brightness: 57
Color: 58
Hue: 0
Color Temperature: Warm 2
Sharpness: 0
Noise Reduction: Auto(because im not using a cable box)
MPEG Noise Reduction: Off
CineMotion: Auto
--Advanced settings
Black Corrector: Off
Adv. Contrast Enhancer: Low
Gamma: -1
Live Color: Off
--White Balance
R-Gain: 0
G-Gain: 0
B-Gain: -19
R-Bias: 0
G-Bias: 0
B-Bias: 2
--Screen adjustments sub-menu--
Wide Mode: Full
Auto Wide: Off
4:3 Default: Off [grayed out]
Display Area:
Auto setting: un-checked
Manual setting: Full pixel
Screen position: [grayed out]
Vertical size: [grayed out]
post #32 of 39
Your local HD stations available OTA should also be avalable with your standard cable since it is your TV tuner that determines what unencrypted HD channels you can tune.
If a HD LCD/LED TV does not list the refresh rate as 120Hz, or 240Hz in the specs then it is 60Hz in North America.
post #33 of 39
I am pleased with these settings...FANTASTIC on HD and even good on SD content
Picture Mode Cinema
Backlight: 10
Picture: 77
Brightness: 53
Color: 50
Hue: 0
Sharpness: 5
Noise Reduction: Auto(because im not using a cable box) Off for bluray and dig cable/sat
CineMotion: Auto
--Advanced settings
Gamma: -1
Live Color: Off
--White Balance
R-Gain: 0
G-Gain: 0
B-Gain: -19
R-Bias: 0
G-Bias: 0
B-Bias: 3
Wide Mode: Full
Auto Wide: Off
Display Area:
post #34 of 39
Since the TV updated to the newest software it now won't update apps. When I go into Google Play and then My Apps. I have apps that need updating. I tell it to update and I get a message that "com.android.vending" has stopped unexpectedly. It forces me to select the "Force Stop" button. Same thing happens if I try to download an app. Any ideas? I have power failed the TV but no fix. I have the Sony 32" Google TV.
post #35 of 39
i would do a factory reset on the tv.
post #36 of 39
Did Sony automatically update the software on your TV.? If not are you sure that the update you applied applies to your TV's serial number since not all updates to a model apply to all serial numbers of the model.
post #37 of 39
The TV automatically one day said a update was available. I'm assuming it must be going to Sony for the update. Any idea how to do a factory reset?
post #38 of 39
Goto settings then goto Privacy and safety then goto Factory reset.
post #39 of 39
Does anyone know how to change the User Agent to Custom Agent? I found it in the menu but don't know how to enter the new code. I'm trying to change it so I can watch HULU.
