Originally Posted by
joeblow
Hmmmm. Can you press pause at the beginning to allow it to buffer the data for awhile, and then watch it later? Hulu allows this.
jamieva
I believe so. But honestly it doesn't stop to buffer very often at all ( i have Verizon Fios for internet) so that has only been an issue once in a while.
joeblow
I guess I was thinking about how some service throttle the streaming quality if your speed fluctuates. I don't know if that happens to NF; it sounds like if there is a major online traffic problem that it'll just pause automatically.
From what I've always been able to tell, Netflix will buffer about 3 minutes, give or take. You can see this in the PC streaming...start it up, pause it, and the "buffer line" will build for a little bit, then just stop (I assume this is the same for the devices, but there's no buffer line to verify). This is unlike something like Hulu or Youtube that you'll see the buffer line just buffer the entire video all the way to the end. I assume this is to save on some bandwidth in the event someone stops watching, or (as most people do) stop the movie at the credits instead of watching those 5 minutes or so, or when people FF or Rewind (so the buffer/bandwidth is not wasted).
Netflix does fluctuate the quality depending on your speed. Usually this is pretty quick (I'll see it flash...at least on the XBOX....with a message about available bandwidth changing and adjusting playback speed....and then a short rebuffer). This usually happens all in under 1 second. If the bandwidth goes down, it lowers the quality, if it goes up, it raises the quality. The ~3 minute buffer is to account for fluctuations, I assume.
I should point out I rarely ever have this issue where it has to rebuffer for some reason. I don't even remember the last time it happened, but I'm also on a 15-20 connection.
Also keep in mind that it's not really streaming in the sense you can only watch what has been buffered/downloaded. You can FF and Rewind at will and it picks right back up (similar to how you can skip around in a YouTube video, regardless of what's already been buffered)
