AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Home Theater Demo Disc - Version 2.0
Home Theater Demo Disc - Version 2.0 - Page 44
post #1291 of 1589
Originally Posted by JChin View Post
Hi cybrsage, this all new to me. Is this method (if I understand correctly) to change format and store it on my computer (I guess the Hard Drive), then be able to stream this material to PS3 through Window Media Player via Network?
If so, can you post a step by step on how to do this. I had try the thumb drive technique method at the other thread (Reference Blu-Ray Demo Disc) and was unsuccessful.
You can't stream a bluray to the PS3. It needs to be on a disc or on a hard drive as previously mentioned.
post #1292 of 1589
Originally Posted by shadowcaster View Post
The link is dead, long live the link ! : http://www.mediafire.com/?z515gvl8ugimad9
Yesterday I started downloading from the link using bit torrent and got up to 7.3 GB. Then Bit Torrent gave me a "files missing" error and now it says "The Network Path was not found".
I'm new to torrent downloading but don't think I'm doing anything wrong. Is anybody else getting the demo downloaded okay?
Rod
post #1293 of 1589
Rod
Is the drive you're downloading it to still accessible?
post #1294 of 1589
Originally Posted by MichaelCarey View Post
Thanks for that... it's starting to make a bit of sense now.
I've also found a folder on my media server called :-
Home Theater Demonstration Bluray V2.0
With BD content and cover art.
Is this a ScubaSteve "production"?
Yes, that's Scuba Steve's version 2 disc. His older version 1 disc was named differently, I can't recall exactly how. But the resultant discs are pretty similar, except for some differences in clip selection. The background image used on the menus is the same so it should be pretty obvious that the two are related, however.
post #1295 of 1589
Originally Posted by goneten View Post
Guys, would anyone be willing to copy this material on to a disk for me. I'll pay for your time and the disk. Really want a Blu-ray demo disk...but I couldn't be bothered to download 40+ GB of material. Please PM if you can.
No one is selling discs. That's a big no-no. You'll need to find a friend to download and burn it for you.
As I understand it, little home-made demo projects are being ignored by the powers-that-be, but if money starts changing hands, the legal departments at the studios are going to come down like hammer, and AVS will cut them off immediately, plus you're on your own with the legal fight.
Please don't screw this up for everyone. NO MONEY.
post #1296 of 1589
One big difference is that Ver 1 had music video clips, while Ver 2 doesn't.
post #1297 of 1589
Rod
I tried starting it just now too, but i don't see any seeders... Looks dead?
post #1298 of 1589
Incorrect....I just checked and there're 6 seeds and 17 peers. Far from dead.
post #1299 of 1589
thanks for checking.. still not sure what's wrong on my end. My client still says "connecting to peers".
post #1300 of 1589
Hopefully you're using uTorrent?
post #1301 of 1589
yeah i just figured out the issue.. "error: Problem connecting to tracker - (111, 'Connection refused')"
I'm using transmission on torrentflux. Any way to get it to work besides uTorrent?
post #1302 of 1589
Anyone have a tutorial on how go from the torrent site to a finished bluray disk playable on most bluray players?
post #1303 of 1589
A torrent is a torrent. As long as your application is configured correctly, it should work fine regardless of client. It's like a website... doesn't matter whether you're using IE, Firefox, Chrome or Safari, you're surfing to the same site.
Sounds like you may have a firewall issue, but check your application's support site to be sure. Transmission is a good app, that shouldn't be the problem. (Note that I do believe uTorrent has a Mac version now, if you decide to try that instead.)
post #1304 of 1589
SuperLeo posted a nice how-to in the thread for his demo disc, the same basic steps should apply here, too:
http://www.avsforum.com/avs-vb/showt...5#post21843235
post #1305 of 1589
Thanks. I've used transmission for years, but it failed for some reason with this file. I just downloaded utorrent and it started up just fine. Weird...
post #1306 of 1589
Thanks very much for your question. I had thought that the error message referring to "Network" meant the Internet, not my network. Anyway the computer the drive was on was off for some reason.
I now have it all downloaded and just need to figure out what to do now to get it in a playable form for JRMC on our HTPC. Looks like there's a lot of old posts in the thread explaining things so will do a review of them.
Rod
post #1307 of 1589
Rod
I use this in JRMC frequently. I tagged each m2ts file with its contents. We can't use the menu in JRMC, so I tagged each file with an album, depending on which category it was in- eye candy, LFE, surround etc.
There is a partial list of the files somewhere and I could send it to you if you want.
If you play the whole disc in JRMC, it will play in a seemingly random order and will not change audio codecs after the first segment, so that's not desirable at all.
I should add that I did all of this for version 1 of the demo disc, and haven't got around to it for version 2 yet.
post #1308 of 1589
Cool. Thanks for that...
Michael.
post #1309 of 1589
Does anyone have the Hi-res Cover art for Demo Disc version 2.0?
post #1310 of 1589
Hello all. Can someone help me out by pointing to the various posts that can get me the following:
1) Which software to get for Bit Torrent
2) What link to follow to get the demo after installing Bit Torrent Software
3) instructions to burn it to blu-ray disc.
Thanks..I am trying to find it, but 1200+ posts is daunting.
post #1311 of 1589
Hi kezug, this is what I gather. Someone please correct me if I'm wrong in the following.
http://utorrent.en.softonic.com/download
UnZip / Extract using
http://www.7-zip.org/
or
http://www.downloadwinrar.org/
Download Mirror 7 - Provided by ImgBurn
http://www.imgburn.com/index.php?act=download
How to burn
http://forum.imgburn.com/index.php?showtopic=9512
http://www.avsforum.com/avs-vb/showp...&postcount=396
post #1312 of 1589
^^^ Thanks! I will provide feedback to let you all know how it goes.
post #1313 of 1589
or
How to burn
post #1314 of 1589
ok, so uTorrent was downloaded and the download is occurring now. Its been going since Saturday and is only 40% complete! Its going to take about 11 days. Ugh. Is this normal?
Is there any option to get this to download faster?
Is anyone willing to burn me a disc if I ship them to you and pay for shipping in return?
post #1315 of 1589
I'll seed and hopefully help speed
post #1316 of 1589
From what I can see you're finished .
post #1317 of 1589
I just wanted to say thanks for those helped put this together. After days of downloading I got all the files. Really nice test clips for a home theater.
post #1318 of 1589
Actually, I am having someone help me out with the download and burn since they have the burner. I will check with him soon as he had to pause the download due to it sucking up his home networks bandwidth causing issues for his work at home wife.
post #1319 of 1589
^^^^ yep, we are paused until tonight...will resume downloading tonight, if anyone can seed, we'd appreciate it.
post #1320 of 1589
Been seeding for days, thought i should seed at least as long as it took me to download, to give back!
