Originally Posted by
scubasteve2365
I initially was going to include them, and my first test-disc had them, but the source for the clips were 1920x1080p @ 60Hz.
If the source was a professional BD, or even a home brew authored with pro software, 1080p60 (59.94) and 1080p30 (29.97) cannot exit. I'm not sure that even multiAVCHD would accept non-compliant 1080 video.
While the Scenarist manual quotes 1080 60i and 1080 50i, I hate those nomenclatures as all values should be in FRAMES per second and not bounce back and forth between FRAMES and FIELDS. Just a little pet peeve of mine
The only 1080p that is part of the BD spec is 23.976, or exactly 24. I hate the fact that even after dumping NTSC analog in this country, we are still stuck with the legacy frame rate.
If, per chance, the source was 1080i29.97 and the video is 2:3 pulldown, it would be easy to take the 2:3 content and convert it to 1080p23.976, by using AVISynth, a recent Nvidia graphics GPU + DGDecNV and recode using x264, at a bitrate of 20 Mbps, or higher (2-pass VBR). I doubt that you would see any quality loss.
If you need some pieces recoded to remove telecine, send me a PM for details.
