AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Home Theater Demo Disc - Version 2.0
Home Theater Demo Disc - Version 2.0 - Page 51
post #1501 of 1580
Ok ,so I have downloaded the complete file as well as "imageburn" but I'm a little confused at this point about what to do next.
I have access to a blu-ray burner and my media is a Maxell BD-R dl 50 GB disc.
However the player in my home theater is a Panasonic DMP-BD-60 and I'm not sure if I need to apply the patch to get this disc to play.
I checked the compatibility list and it says that it should play both HDMV and AVCHD with this note in the known issues:
"Panasonic players using the AVCHD version may find that the HDTV Calibration video lacks chapter skips and a popup menu. The top menu button on the remote should still return to the main menu, and fast forward or rewind should be able to move through the HDTV Calibration video. At the current time we are not aware of an alternate AVCHD authoring method to solve this reported issue on Panasonic players. The HDMV version burned to BD-RE or BD-R with a Blu-ray burner should include the chapter skips and a popup menu on the same Panasonic players"
So , do I need the "patch" and if so where do I get it and how do I apply it?? confused.gif
post #1502 of 1580
I am not sure, but if you burn the disc as Bluray and noct DVD and AVCHD yaou don't need to aply a patch.
I also downloaded the 2.0 and burned yesterday on a 50 Dual Layer Bluray Disc. With speed 2x and put the both folders CERTIFICATE and BDMV as source on imgburn.
So i think AVCHD is only if you burn on a DVD not original Bluray.
I forgot to say that my Player is the Panasonic BD310
post #1503 of 1580
The patch is only if you are going to burn the individual segment into a DVD (BD9). There is nothing special or different to do when burning to Bluray media.
post #1504 of 1580
post #1505 of 1580
I'm going to try to burn it tonight !!
post #1506 of 1580
I finished burning the disc and I just gotta say WOW !!!
This is one great disc and works perfectly !!!
post #1507 of 1580
For those running these files directly from a laptop or PC, what software (and codecs) are you using?
I'd like to run these to my receiver via HDMI output, but windows media doesn't seem to have the correct codecs for audio. Video appears fine.
post #1508 of 1580
Pretty sure you need a package like ArcSoft TotalMedia. Windows doesn't have built-in codecs for BluRay.
post #1509 of 1580
Originally Posted by superleo View Post
Found the torrents for both of Steve's torrents:
Home Theater Demo Disc - Version 2.0 --- http://www.mediafire.com/view/?o350r60kr0x0m88
Another 1080P Demo Disc Project - Version 1.0 --- http://www.mediafire.com/view/?y271j10xx29zt7d
Can someone upload these torrents again? Says the account has been suspended.
post #1510 of 1580
Why aren't you using the ones at the beginning of the thread? Post 8.
post #1511 of 1580
*smacks head* thanks, I must have skimmed right over them.
post #1512 of 1580
I tried the link on post #8 and it opens GoforFiles exe but when the program searches, I am not sure which file I need to download. I also tried searching Home Theater Demo Disc but a lot of results come up. I'm not sure which file to download. Can someone let me know the exact search term and file name to download?
post #1513 of 1580
Ok, I went over to this thread and found the file to download via uTorrent. http://www.avsforum.com/t/1391873/reference-blu-ray-demo-disc-bd9-dvd-dl-media-bd50/0_100
It's downloading the 36GB file, and might take all day, but it should be fine to have a reference bluray disc to play with. I also removed the GoforFiles program that installed in my previous post. Sorry, I'm all new to this whole torrent thing. Never done it before.
post #1514 of 1580
I ended up googling and found a "media player codec pack 4.2" on Cnet.
It seems to work quite well. The video content looks a bit different when output from the laptop (e.g. it has much more SOE than a physical disc). My receiver seems to interpret the audio content correctly (e.g., it indicates its receiving DTS-HD etc.). For now, its a reasonable alternative.
post #1515 of 1580
Originally Posted by Dradius View Post
Against my better judgement I went ahead and installed that crap. Surprise surprise, it is wortheless. If anyone does find a .nzb please let me know.
I was able to grab an NZB file for this disc here:
http://binsearch.info/?q=home+theater+demonstration+bluray&max=100&adv_age=1100&server=
Pulling it down right now at 3.2MB/s.
post #1516 of 1580
from the looks of it, they are all incomplete. hope there are enough pars. please update when its done.
post #1517 of 1580
I forgot to check before I left the house this morning. I'll update you later.
post #1518 of 1580
It downloaded and extracted just fine via Astraweb. I grabbed the 471 day old version uploaded by Yuuza.
post #1519 of 1580
Home_Theater_Demonstration_Bluray_v2.0.torrent.txt 277k .txt file
Here it is, just remove the .txt at the end of the name.
If I'm not allowed to post this just say it and I will remove it
post #1520 of 1580
Hi guys.
Could someone point me in the right direction to what I would need to make my own demo disc? I want to make a compilation of my favorite scenes. (Is their a thread on the subject?) if its in this thread I'm sorry; I'm using this tapatalk app and can't use it right I guess)
Thxs
post #1521 of 1580
Nevermind. Found a thread. Thxs anyway.
post #1522 of 1580
Can scubsteve's Bluray discs be bought if we cant burn our own ??
post #1523 of 1580
No, for legal reasons it can not.
post #1524 of 1580
...Wonder if anyone would burn me one if i paid them ???
post #1525 of 1580
post #1526 of 1580
You would need to find someone willing to burn it (for free) and provide them with the media since it can be pricey, but that would be it. Any payment for the "service" of burning would be considered making a profit off of material that they did not own the rights to make a profit from.
post #1527 of 1580
hi Nick. I think you may find that the copyright owners have tightened up on the copying process. Most new movies come with the FBI warning stipulating that it's an offence to copy the movie regardless of whether a profit is made. Whilst I agree that burning this disk myself has resulted in me purchasing a number of the titles, it's still a very slippery slope in terms of legalities.
post #1528 of 1580
..Well if anyone is willing to burn me one for my Bluray ,just PM me and we will work something out !
post #1529 of 1580
Got it to burn first time through, no coasters! Would be helpful if this info could be added to the instructions on the first page for IMGBurn. had to search many pages to find it:
MODE1/2048
UDF only
UDF Revision 2.5
Label: AVCHD
Thanks for all the hard work putting this through. I am burning the other "Reference" disk now.
post #1530 of 1580
^^^ When you place the files into IMGBURN, it automatically sets it to UDF 2.50 and brings up a dialog box confirming that it wants to do that.
The AVCHD label is incorrect, as the disc is not an AVCHD formatted disc, it is a 100% authored Blu-ray format disc. The label is more like:
HomeTheaterDemo_Ver-2
