Originally Posted by
Haps
I just got my version 1 disc in the mail(Thanks scubasteve). Anyways the one things that stands out to me is that there is some 3 hours of video on the disc.
It would have been nice to have somewhere to select 30min demonstration and it would run through clips. Jumping from clip to clip.
Basically the inclusion of playlists. Maybe people that have the disc can pip up with their playlist. I'm sure people don't sit visitors down and play the whole thing. Which clips do you play and why?
If there were some go to playlists on the discs so just sit down press play and forget about it. That would be great.
Haps,
The disc purposefully contains 3+ hours of clips, wherein the collection of clips each have different strengths, even differences within the same genre/section.
For example, the LFE section may have 1 clip that performs better on your system than mine, however a different clip may perform better on my system than yours.
Since everyone's theaters have different strengths and weaknesses it would be impossible to select the best 30 minutes of demonstration to create a playlist. If we could have the best 30 minutes objectively, this disc would be on a DVD and would be cheaper for everyone to either buy or download/burn.
I've put an emphasis on navigation, so you should be able to navigate from clip to clip with relative ease. When you demo your system feel free to select the best 30 minutes, you'll just have to manually go from clip to clip.
With that said, I'll be doing a "play-all" for v2 and will look into a genre/section play-all as well.
