AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Home Theater Demo Disc - Version 2.0
Home Theater Demo Disc - Version 2.0 - Page 15
post #421 of 1578
Originally Posted by Kalani View Post
The total size is over 46gb, so no way you've downloaded only 345mb and have 37.7% of 46.1gb. If you actually have 37.7%, you should have over 17gb downloaded.
I think he meant he only downloaded 345MB from the two seeders. the other 17gb is from peers (which they originally received from seeders)
post #422 of 1578
Correct, I have 17.7GB total downloaded but only 345MB from the two seeders. So pretty much 100% from peers which means my download is being limited by the availability of the peers which at the moment is the same as what I have. Is that normal? I have the check mark in the bottom corner for connection health and I was downloading at over 1M last night when I went to bed.
I have uploaded 50GB so far so hopefully that has helped.
post #423 of 1578
This is normal. I can't send out 46gigs to everyone. The torrent system works because I send data to one person and he sends that same chunk of data to 15 other people and so on.
post #424 of 1578
More like you send out the data in chunks to various people, and then they send the chunks out to the others in the torrent cloud, and they send it out, and so on, and so on, and so on.
But BlackHawk, yes, it's normal that you don't get much from the original seeder, when they are few... you shouldn't. If the original seeder was busy trying to send the same bits to everyone who joined in, it would never get done. The strength of the torrent system is that downloads are distributed by EVERYONE, as fast as possible. The way torrents work, they break a big file up into little pieces. Everyone downloads the pieces, and the software reassembles them into one file again on your end. Meanwhile, you can download the pieces from ANYONE in the torrent, rather than everyone waiting in line for Steve's upload to the first guy to finish. So everyone shares with everyone else, and no single person's bandwidth limit can clog up the entire chain.
The exception, is what we're looking at now: The initial seed. It takes days for anyone with a normal DSL-style upload speed limit (much lower than the downloading speed limit) to push out 46gb of materials. No matter who he pushes it to (hopefully only one person... if he pushed 46gb to even two people, it would take twice as long to finish the initial upload!), it's going to take a fixed amount of time. The software usually jumps around, distributing pieces to various people in connected in the torrent's cloud, so they can turn around and send them to others, without overwhelming any one person too badly.
As Steve pushes one chunk to someone, that person now has that piece also. And now they can upload it to someone else (without slowing Steve down any further). Then there are three people with that initial chunk, (while Steve continues to push pieces out to that first person or others, in the background). So if you join in right then, there are three people pushing out those early pieces all at once, so your download speed of those initial pieces ends up as an aggregate of all the other people's speed (possible three times Steve's original upload speed, at that point). Once you get 30, or 100, or 500+ people all sharing the same bits of the file, your download speeds can get insanely fast.
BUT, eventually, in these early phases, you catch up, and you have already downloaded everything that's Steve has thus far managed to upload, with his single DSL line. That's the slow situation we're currently in. If he can get the files to someone else via personal delivery/fedex/whatever of a drive, they can join in as fully-participating seeds as well, which would cut the initial seeding time in half, but I guess that didn't work out as hoped due to a problem with the initial file.
In a week (less, more likely), once Steve manages to push out the full file, a whole bunch of people will be seeding the file all at once. So your download speed will be silly fast... likely, as fast as your line is actually capable of working, literally pegged at the limit. But not until enough people have the whole file, which brings us back to the initial seed's upload speed limit.
Going back to your initial question, it absolutely makes sense that only a small part of your files will have come from the initial seeders... because everyone else connected is sharing. If there are 100 people in the collective, and only one of them is seeding, your odds are 1 in 100 that any particular piece will have come directly from the original seeder, as opposed to someone else.
I've simplified a bit, but hopefully this is at least somewhat clear, so people understand why it's slow at the moment, and how it will speed up soon enough.
More here: https://secure.wikimedia.org/wikiped...%28protocol%29
post #425 of 1578
Fascinating tech.
I'm now at 40% and have uploaded 43GB.
Curious, it says I've only downloaded 12.8 GB, but that's probably because I already had a fair bit downloaded with the previous torrent.
post #426 of 1578
Thanks for the great summary confirming what I figured was probably the case.
post #427 of 1578
47% done... uploaded 195 GB!
post #428 of 1578
Still at 47%... along with all of my peers. Did the seed go down last night?
post #429 of 1578
Nope. 55.6% done. Don't sweat it. Right now it's like a race to a red light. It doesn't matter really how much you have done. All that matters is that someone is getting it.
post #430 of 1578
I'm now at 56%, looks like I'll have it for the weekend. :-)
post #431 of 1578
Originally Posted by Geezer View Post
Need more torrent participation. Don't want to wait 3 days!
Downloading at 120k, uploading at 680k...says there is only 1 seeder...
post #432 of 1578
Yeah, although the torrent occasionally says there's 1.x availability (currently around 1.586), there really is only 0.586 availability since Steve is seeding to only one place to keep his upload fast.
It'll still take another couple days I think before it's fully available. By that time, people who started torrenting early will have the whole thing, but also, there will be a huge number of seeders and it'll start downloading a LOT faster.
post #433 of 1578
A second seeder just appeared and my download speed just jumped a bit. I should expect it to be unstable for awhile, until more people get it.
Thanks for the info.
post #434 of 1578
I was getting fast download and upload speeds last night. But today it dropped to 10kpbs and I don't see any seeders as well. Did everyone stop seeding?
post #435 of 1578
No, the seeds are there and fine. I see all 3 of them.
1) My house
2) My office
3) The AVS seeder
Not everyone is going to be connected to a seed at all times. No worries.
post #436 of 1578
But why I am done downloading 48%. I want to download it ASAP so that I can test it out.
post #437 of 1578
You are going to be done with it when everyone else is. I can only upload so fast. You don't get it all from the seeds. Read the long post above that explains how torrents work. The majority you are going to download will be from other peers. At most, you might download a few percentage points from me directly but the rest from other peers (and when those peers complete they become seeders).
Between my two personal seeds I'm only capable of sending out about 200kBytes/s (1.6Mbit).
post #438 of 1578
Read post #426, just a few up. Then put on your thinking cap.
(or perhaps reverse that, and put on the thinking cap before you read the post!)
That's why. We ALL want it now! But until Verizon gets around to deploying FIOS to every house in the country, some people have slower upload times than others... and it turns out it just plain takes a long time to upload 46gb with a normal DSL line!
The torrent first went live on 8/15, but there was a problem, so really 8/16 (in the afternoon). So by this afternoon (8/18, Thursday), it will only have been truly live for 2 days, and we're already at about 60% available. At an upload rate 30% per day, we should be at 90% sometime tomorrow (Friday) afternoon and it should be fully available by sometime Saturday morning, I'd guess... maybe sooner if we're lucky, but that's what I would bank on.
Anyone joining in the torrent Saturday afternoon, Sunday, or perhaps better still Monday, their download speeds are going to FLY all the way to completion. It's only the early adopters who have to suffer through the initial download slowness (and anyone who comes too late to the party, like the people who were still trying to download the v1 disc over the past couple of weeks, with so few participants remaining).
post #439 of 1578
Thanks for doing this Steve, really looking forward to the new disc. Any timeline for when you are going to start mailing out purchased copies?
post #440 of 1578
I'm in the mix now too! Just got back from scuba diving with my Boy Scout Troop at the Florida Sea Base. I have the torrent and am downloading it as we speak. Thank you Steve for pulling this together again!
NoVA crew, PM me if you need help with this.
CJ
post #441 of 1578
+1 for that!! I have no burner and would love to purchase a copy!! Kudos to one of the best ways to really demo your system!!!
post #442 of 1578
Just wanted to say thank you for making another disc for us to enjoy and show off our theaters. I have yet to invest in a bluray burner as dual layer blurays are still too expensive (artificial held up to keep them that way). So I purchased the disk as I feel you deserve a little for your time and effort.
Thanks again!
post #443 of 1578
I am at 62.25% complete and counting, so it is definately still working.
However, my downloading speed just dropped down to slow speed so it will take anotehr 2 days to complete.
That said, I know it will pick back up again at some point, so it will be much sooner than that.
Right now I have to limit my upload to only 600k, else my download takes hit...once I have it all downloaded I will change the upload to unlimited again.
post #444 of 1578
Someone needs to post this to the newsgroups, then once its posted there is no waiting for anyone, you can download it at your max connection speed....
post #445 of 1578
Right but it would take a week for me to upload it there so it doesnt save any time, in fact its slower because at least now i have 3 seeds doing the upload work simultaneously. Then and only then could people start the download.
Once there are a few copies out there this will be at a max connection as well.
post #446 of 1578
I am on a superfast connection, and would love to upload it to the newsgroups once I get it. But I started to download it through torrents and I was only downloading at 150k, I let it go for a few hours today, and still only downloading at that, but I am uploading at 2500k.... I have a 50mbps connection up and down, and could have it posted to the newsgroups in about 4 hours once i get it...
post #447 of 1578
It sure is funny how history repeats itself.
post #448 of 1578
Except maybe this time someone will actually post it to the newsgroups...
post #449 of 1578
Feel free.
(echo... echo... echo...)
post #450 of 1578
Was still stuck at 47% with a whole bunch of peers. Turns out I had the wrong torrent. Downloaded the new one and now I'm off and running. That was a waste of 20GB!
Anyone else stuck at 47%, you may have the old torrent, too.
