Hey All,
I've been checking out the Prodigy product line again. I'm interested in their new HDMI 6 x 6 switch. I guess it only distributes video so a separate audio server is needed. How does it handle EDID? Their higher end DM product will send the highest resolution possible to each individual device but I'm concerned the Prodigy will just down convert to the lowest common resolution? For the audio aspect, I have two areas where I would like 7.1 surround and then 11 zones of stereo audio but I'd like to centrally rack everything. Is this possible?
Has anyone heard if the ADMS will support BDMV or ISO. I rip my discs to either format depending if I want the full menu structure or just main movie. I've looked in the Dune as a front end but the IP control isn't there yet and I want a better GUI then it or its jukeboxes display currently. I know netgear is coming out with the NTV550 which is supposed to play everything but I haven't heard about IP support yet, nor its GUI.
I'm assuming the ADMS will be able to get content from the new WHS vail. Has anyone tried yet? When doing a global search...will ADMS prioritize the content I have locally on my network on the display page?
PS3 integration?? I currently use my PS3 in my great room but I'd like it available in a couple other rooms. Can Crestron distribute the signal with two-way feedback (allowing games to be played) or do I have to rely on the bluetooth distance from controller to unit?
Security integration. Will Prodigy integrate with my current system which uses DSC panels?
Will prodigy eventually incorporate pool and sprinkler control?
Thanks for the help
Thanks for the help
