Originally Posted by rntlee
The only schematic of this amp I'm aware of is this one(I got it from Song @ Canadian Hifi Online):
Attachment 238521
It's possible there are errors, I haven't had my amp open yet to check.
My only concern with posting/encouraging internal modifications is the danger to inexperienced modders. Tube amps utilize very high (ie. deadly) voltages. There's 450V at hand inside the MS-20L that will give anyone who comes into contact with it a very bad day.
That said, one modification I did need to do with mine was to place a bucking transformer between the amp and the mains voltage. I'm in Canada and my measured household voltage is 126-127VAC. This is a little high for this amp, which seems to be designed for a voltage of around 115VAC. The heaters on the tubes are to be run at 6.3v for maximum tube life. Mine were at about 6.9v, which would have shortened the tube life by about half:
Attachment 238526
I bought a boost/buck transformer from ebay and it drops my 126VAC to 115VAC. This amp also uses a SRPP for the input stage, which is pushing the heater to cathode voltage in the top 6J1 to the max allowable. I may have even been exceeding it with my high mains voltage.
Attachment 238521
Attachment 238526
Good point about modding these amps, I was a TV repairman in the 70s, remember tube TVs? I "lit myself up" more than once back in those days
Here is Song's email, you might want to ping him and ask about availability:
