AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Optoma GT720 Ceiling Mount?
post #1 of 7
I'm new to the projector scene and have no idea which ceiling mount to get. I've run across 3 and wondering if you guys have any experience with them or have better recommendations?
$25
http://cgi.ebay.com/Projector-Ceilin...efaultDomain_0
$32
http://www.amazon.com/PCMD-All-Metal...f=pd_rhf_p_t_1
Or these guys:
http://cgi.ebay.com/PROJECTOR-CEILIN...item335d4cb643
Any help would be greatly appreciated!
post #2 of 7
I'd like an answer to this as well. None of those look like the one on optoma's website. Thanks.
post #3 of 7
Can anyone recommend a good brand for ceiling mounts please??
post #4 of 7
yep I need the same thing for my gt720. Anyone out there?
post #5 of 7
a lot of people here like Cheif mounts. BTW how does the GT720 do on movies and HDTV?
thxs Thain
post #6 of 7
Hi guys I have the GT720 as well and I have bought the all metal mount. I really like it. I got mine from E-bay, but it is probably the same manufacture. There are knockoffs though so be careful.
As far as movies and HDTV you will not be dissappointed. It has a great picture and I show mine on a wall with Behr Silver Screen paint.
post #7 of 7
Here's what I have my eye on for a mount...
Premier Mounts: Wall Mount for Short-Throw Projectors
Only extends 57" but from the projector calculator at projectorcentral.com says that will still give me up to 106" diagonal at 16:9 which seems like plenty space for me, gaming or otherwise.
Costly as all get out but I like how sturdy it is and with a vaulted ceiling and a ceiling fan, it seems to be the most practical solution.
