Originally Posted by MikeE21286
So having some problem with my new WD TV Live Media Hub around an external USB hard drive
FYI - I've upgraded to the newest firmware.
The USB hard drive was plugged in and worked fine. I tried to eject the hard drive from the system, but it froze (basically it showed a loop signal that continued to loop for hours and was still doing so when I woke in the morning).
I unplugged the hard drive and turned off the machine.
I plugged my hard drive into my computer and it asked to scan for errors. I declined as this is a large hard drive (2TB) and I did not want to do so.
I added a couple new files and plugged the hard drive back into the WDTV Live Media Hub and it was now not recognized.
Looking around the internet I"m seeing that this is a common issue? That I HAVE to eject the hard drive in order for it to be plugged in successfully again after removal? The problem is the device wouldn't let me do so :?
I'm currently scanning the hard drive (on my PC), but it's gonna take foooooorever. This is what was recommended on another forum post I saw.
Thoughts/Advice?
Thoughts/Advice?
Did you unplug the power cord to the Hub besides just turning it off? If you suspect something was corrupt you can delete the .wd_tv folder (**EDIT** Make a backup of this folder first just in case) in your external hard drive and then hook it back up to the Hub. Of course the Hub will have to REcompile the media library but at least it will give you a clean fresh start.
Hmm not sure how to set this up the way i want.
