Originally Posted by WDFan1970
Keep in mind the Twonky Server does not transcode. So the media Twonky is serving must be compatible with the app or device that's receiving it.
So if your Sony BD player can play the files you have via DLNA, then you'll be fine.
I've used Buzz Player for the iPad on occasion... It does work, but again, the original files must be 100% iPad compliant (meaning MP4 / h.264 video and AAC or MP3 audio in either a MOV or MP4/M4V container.)
Argh. The reason I got the WDTV Live Hub in the first place was because I didn't want the hassle of trying to transcode/convert files to stream them from my PC to my TV via the Sony Blu-Ray player/Xbox 360.
So here's another question: If I run Serviio (which transcodes, I believe) on my PC, can I also have it serve up and transcode video files from my WDTV hub to my Blu-Ray player and iPad, regardless of format (assuming the transcoding works)?
Anyone know of the best (most reliable) way of streaming files (NOT THROUGH ITUNES) from a PC or Hub to an iPad?
