held off for months doing the FW upgrade until this weekend and now also getting the "The Last Content Source Has Been Removed" error which never got before. Also unit never was fast before going between folders or shares but now definitely a pig taking a minute or more.
Most of my media I access through Media Library since sitting on a DNS323 NAS.
Hoping as well for a solution.
), but the same problems. I also disabled media library rebooted and re-enabled (this I read also re-builds the library). Still no joy. I may try deleting all the MP3s .... then all the AVIs , etc to see if I can find out what type of media is causing the unit to go wacko. Or do you think I should roll back a version on the firmware? It seems like others are seeing this problem on the latest version.
A van with 8 seats can hold 8 passengers -- only if the maximum load isn't otherwise exceeded. Put 8 500lb passengers in it and it'll be riding on its springs or break an axle.
