Originally Posted by
allinat420
I was not able to get the wdtv hub display on my computer monitor with a dvi output...even though i had a hdmi to dvdi cable...
Since i am using a projector in my bedroom which has no network cable i was simply trying to get my movie collection on the internal drive...
I was trying to get into the configuation menu that you access from here:
http://192.168.0.5/index.php
and amazingly it asks me for a password.
I could not find a password in any of the documentation and when i called tech support at wd they were clueless.
Pretty frustrating...i decided to order a wirless n access point for 70 bucks to try to alleviate this problem...so then i can connect to the network from my bedroom... i have no idea if this is going to work.
I think you are confused. There's no webserver at
http://[hub IP]/admin.php.
The WebUI screen begins at
http://[hub ip]/ ... WITHOUT any document name.
The password is listed on page 71 of the manual.
... and how are you connecting to it if you have no network cable, and no wireless?
...To get movies on the internal drive WITHOUT a network, you're going to need to transfer them from an EXTERNAL drive plugged into the USB port.
