AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › JapanDave dedicated theater build.
JapanDave dedicated theater build. - Page 4
post #91 of 588
Originally Posted by Dixon View Post
That makes sense to me. If the room is sealed concrete, including the ceiling, I suspect the only leakage concern (apart from any holes you cut in it) would be something clicking/banging on the concrete. That doesn't appear to be an issue for you.
Thx. Cool space.
No worries, like I said I am no expert and it good to be kept on my toes.
post #92 of 588
Thanks for all the pics, great detail on the building methods.
When the acoustic plan for the room was being developed was your input sought when determining a target RT60 for the room or was it left completely with the designer? I find it impressive and speaks highly of the skill of the desginer that a complete arms length acoustical plan can be developed to achieve set goals including satisfactory RT60 plot. To that end is specific seating and carpeting also outlined in the HT plan? Also, are there provisions when the build is complete for an acoustic testing phase which would identify any areas which may require a few wiggle changes for the ratio of aborption/reflection/diffusion?
Anyways, outstanding build and design.
post #93 of 588
Hey Hughman, thanks for stopping by.
The acoustics were left completely up to the designer, I am just assuming that the desirable RT60 is within a certain range and Dennis made the plans accordingly. Something that I have not thought about, but Dennis has said that there is a lot of absorption in the room and I should not have a problem with the very low frequencies. I know that is open for interpretation, but I plan on taking measurements(This is not included in the agreement, but if changes or adjustments are needed I am sure I will have Dennis's help in one way or another.)
As for the carpet, specific carpet and underlay are part of the initial designs. Seating type was not talked about except the number of seats that was going to be used.
Thanks for the words of encouragement
post #94 of 588
It is very difficult to ever consider seating within the context of acoustics in a residential sized room. The biggest single show stopper is that none of the available home theater seats or recliners have been measured under various conditions...yet
post #95 of 588
Dennis , very good point, especially since my room is not considered big.
Edit: I also wanted to add, that it would be pretty difficult for Dennis to make appropriate measurements when I am here in Japan, especially not knowing what equipment I have.
post #96 of 588
Yet.
Mike
post #97 of 588
Great information, thanks. Regarding the post build acoustic analysis I was thinking along the lines of what you are planning to do. Do the measurements yourself following explicit instructions from the designer and he/she would interpret the results and outline any necessary tweaks if required.
"and I should not have a problem with the very low frequencies"
Seeing what subs you're installing the only problem I would anticipate is your eardrums exploding and lodging malleus shrapnel in your brain, other than that you should be fine.
post #98 of 588
That sounds like a great plan. Of coarse I recommend Dennis to do you designs, very professional and his responses to any queries I had were answered very quickly. I really did have piece of mind when finalizing everything from the designs to payment, considering I am here in Japan. Something I have not actually thanked Dennis for yet. Of I understand it is entirely up to you, just wanted to share my experiences.
I forgot to mention these 2 of these dual firing 15" Submersives will also be incorporated into the room, so I will have 4 sub enclosures in room. The Submersives will be going at the back of the room.
post #99 of 588
Yes, that arrangement should suffice. Has sub placement also been predetermined?
post #100 of 588
Only the front two behemoths. The two submersives are going to go somewhere in the region of 24" to 50" from the back wall as close to the side wals as they are allowed to go. Mark (Seaton) is expecting a dip in the 35-50hz region at the seating postion and they will be there to cover that.
We have discussed crossing the Terraforms XL'S around that frequency and allowing the submersives to handle the upper bass in the LFE. I don't really have anything set in stone yet , as I want to hear the system set up and measure it to see what needs to be done.
post #101 of 588
Good plan, very similar to how I ended up utilizing my subs.
On another note, the word "Malleus" (inner ear hammer) would be a great speaker company name, speaker name, subwoofer name or theater name. Should anyone reading this decide to use this name I would expect certain considerations.
post #102 of 588
I just hope I have the smarts to implement this plan!
Now you mention it, I still have not named my theater. Maybe I should let my 6 year old son decide.
post #103 of 588
That's an interesting setup. I have immovable IB subs at the front and slightly movable sealed subs at the rear -- both subs are close to the center line of the room. I'm not ready to perform final calibration but recently I purchased a Berhinger DCX2946 to allow messing with time/phase alignment and equalization of the pairs of subs whilst using REW's RTA monitor to watch the effects. It's fascinating stuff and I would be interested on more details on how you approach this.
BTW As somebody who is 18 months into my HT I'm having fun watching the speed of your build!
Cheers!
post #104 of 588
Cheers!
Just want to say again that your build is amazing!
I will do my best to post everything I end up doing when crossing these subs. I know it is going to take a long time to get the right position of the subs and crossover. By then I hope I will have enough knowledge to give some good advise.
It is moving fast, but preparations for it nearly total one year and that includes getting materials and making them.
post #105 of 588
Cool, Gota see how this one comes out...Subbed !!!!
Looks good so far....
post #106 of 588
Yet.
The "fix" is underway but I'll say nothing beyond that.
...always up for a trip to Japan.
post #107 of 588
If that is the case, I am always up to have a guest. Maybe we can talk about this some more.
post #108 of 588
More updates.
The screen wall is done, minus the black acoustically transparent fabric. Also if you look at previous pics there were orange conduits. Finally got them cleaned up and out of site.
A shot from the side, sorry for all the junk.
A shot above the screen with the acoustic treatments and fabric in place. Forgive the plastic, the room is still really dusty.
The original lights removed and ready to have covers placed on them.
All the sofits acoustic treatments are complete with the fabric in place. Just have to get the wood trim sorted and attached and they will be done, minus the lights.
Apic of the material I used for the sofits,
post #109 of 588
Wow!
I can hardly wait to here about the (?) Dennis visit and graphs of FR curves.
Mike
post #110 of 588
Originally Posted by Mike_WI View Post
Wow!
Mike
I just hope Dennis likes beer, b/c nothing beats Japanese beer IMO.
BTW, the painters are in today the paint the sound proof doors and anything else that needs it.
post #111 of 588
Is the door as narrow as it looks in the photo?
post #112 of 588
Dave
Looking good
How is your HT space in relation with the rest of the house it looks like a bunker but all the better to crank up those Subs.
post #113 of 588
It certainly is. Would you like me to take a pic of what is behind there? BTW, that is not the entrance, it is an access door for a room full of filters for my 2000g fish tank upstairs.
I will post a pic of the tank in the living room.
post #114 of 588
Dave
Looking good
The rest of the house is a bunker too! A bunker with windows!
post #115 of 588
Please do!
Ah ok, I thought that was the entry door
post #116 of 588
Here is a close up pic of the 2000g tank. The biggest fish on the left is about 3' long for size reference.
post #117 of 588
you obviously havent been to germany then!
post #118 of 588
Or Belgium then...
post #119 of 588
No beer, Japanese is all about sake, sushi and geisha ...
post #120 of 588
Originally Posted by FusionRx View Post
Or Belgium then...
thats my second favorite!!!!!
too much choice though in belgium, apparently they have the most variety in the world. thank all the monks for that.
