AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Audio delay in rear surround speakers
post #1 of 4
Do most modern receivers support setting a custom delay timing for the rear speakers? Whoever set up my parents sound system bought a cheap Sony str-de197 which from my research does not support that delay. They have a lot of ceiling speakers in their house and they are all hooked up to that receiver and when they are watching TV, there is a delay between the tv speakers and the surround ceiling speakers. I was thinking of getting them a better receiver which supports setting a custom delay timing.
Mike
post #2 of 4
Mike
That is a stereo receiver so there are no "surround" speakers and there are no distance or level settings. It has 2 sets of speaker outputs which play the same signal. Having no idea how your parents set-up is wired, I can't comment on the specific reasons why they are experiencing a delay.
All surround receivers will allow you to set distance settings. Heck, most modern receivers do it for you!
post #3 of 4
I am resurrecting my old thread as I am looking into this issue for my parents again. Will most current surround receivers output 2 different signals to 2 sets of speakers? What is that feature called?
post #4 of 4
A surround receiver will output separate signals to each of its channels whether it is 5.1, 7.1, 9.1 etc.  If I'm reading correctly I'm assuming they were using the TV speakers in addition to the stereo receiver and there was a delay between those two audio signals.  Your best bet is to do one or the other (TV or receiver) and not both.
