Hey all,
I am in the middle of replacing my current Yamaha HTIB piece by piece and was wondering what order I should do it in.
My inclination is to replace the speakers first and the receiver second followed by the sub woofer last. I think I will gain more by replacing the speakers so I would like to do this first. I just don't want to damage the speakers by under powering them or anything like that. I plan on going with the Polk Audio RTiA7's up front, the CSiA6 center, and the FXiA6 surrounds. Would this blow up my current receiver/ruin the speakers running them on my current receiver?
I am also planning on getting the Pioneer Elite VSX-32 as my AVR, will I need to upgrade to an external amp? I don't think I will have to but this AVR supports preouts so I can if I need to.
No plans on a sub woofer as of right now. I haven't been super impressed with the Polk sub woofers any suggestions to go with this setup?
I've also been confused about power protection, what are your views on the Panamax M5300, M5400 and the Monster HDP2500?
Thank you very much for any suggestions, this is very much a work in progress and I wouldn't even be this far without lurking on AVS all the time!
Andrew
Andrew
It is an unfinished basement ATM with cement floors. This will not be its permanent home, I rent currently. I am really wanting to buy something nice that will last me a while, so accommodating that room specifically is not my goal.
