Hmm done the update still really flakey some work some don't and its not split by library as I thought...
Maybe need to add my titles manually, I'm not sure I trust this aut detect lark.
For example I have in the same library
Akira
Amon Saga
Amon Saga works, Akira doesn't...
I've tried manually adding Akira and same issue, all settings under the disc pop up seem identical. Really really odd...
Did a check via WMC and it works in there for both titles.
How do I check the launch couldn't work out how to do that, MM on Dune keeps restarting itself as well.
A typical Dune folder entry is
icon_path=.Icon.aai
icon_sel_path=.SelectedIcon.aai
media_url=smb://Guest:@DELLSERVER1420/Media Library - 2/Movies/Bond The World is Not Enough/Bond The World is Not Enough.dvd
template_name=PlaybackFolder
Should this not be pointing to a .iso rather than the .dvd.
Akira
Amon Saga
icon_path=.Icon.aai
strangely launching for the dune mm Ui is ok...(while for others it's broken
