I'm no expert but I'll give it a shot...
Originally Posted by HomeGuy
I had FIOS about 2 years ago and the DVR box was so bad I cancelled service after a week and went back to DIrectv. The new boxes seem to be much better. I had a few questions for those with 7232's.
1. Is there a way to search shows without needing to know what time the show comes on. With Directv I can search by show name, actor, etc. Then I have a choice of picking the HD or SD version of the show.
Yes. IMG 1.8 has advanced Search. Search is even better in 1.9 (Month or so out before release).
2. Is there a limit to how many scheduled recordings you can have. Directv maxes out at around 41 (give or take a few). Also, does it tell you about conflicts before they happen or is there just a priority list.
I have not reached a limit. Does not mean there isn't, but currently I have 33 Series Recordings set.
3. In NY and NJ how much (about) does tax add to the triple play at the end of the month?
My tax is just over $24. When (not offered yet, it has been pulled) they offer Digital Voice than no tax so the bill is greatly reduced.
4. With Directv I often (just of late) have playback issues. How are the new boxes? Are they buggy or pretty solid?
No issue with IMG 1.8 that I know of.
5. Is there anything you would change on these boxes which annoy you?
Plenty of positive changes coming in IMG 1.9. Currently IMG 1.8 is only available.
6. Do the boxes support 1080P?
I believe only 1080i, but I could be wrong.
7. Is Verizon considering a 3D channel. I know D is coming out with one (not a deal breaker).
Verizon has plans to offer plenty more HD and 3D. Problem is they need to transition from QAM to IPTV. This is suppose to happen this year but it was suppose to have happened already. No idea when it really will.
8. One last questionand probably the most important. How does the Media DVR work with the 7232's? Is it a link between all the boxes so every box in the house can be networked? Or are only show recorded on the media DVR able to be pushed to the other sets? With D you can netowrk all the boxes and then watch recorded material on any local box in any room.
With IMG 1.8 you can have ONE DVR's recordings viewed on other non DVR's. There are concurrent SD and HD limitations on how many can be viewed. Up to 2 HD's at one time but many can only do 1 HD at a time. This is in addition to whatever is viewed on the DVR. Supposedly that limitation will be increased, meaning more than 1 or 2 HD's. No idea when.
With IMG 1.9 (coming) you can have multiple DVR's and view any recording from any DVR on any box including the DVR's.
