Peter you said "If you want to see the movie correctly without adverts and find the movie metadata easily THE KALEIDESCAPE is the way to go"
MyMovies, dose a great job of "movie metadata" and AnyDVDHD will pull out and the Adverts as well ...I do have to say that K interface is the RBM... maybe they can port there software to work in Windows and then use AnydvdHD what a Great Idea
I believe I can rule that one out unless anyone knows otherwise.
