Here is an Excel spreadsheet that will help you design a few different things in Hornresp. It will model a single/multiple driver horn in TH, Nd, and OD configurations, in 3 or 4 sections. It will also do a BP type of quarter-wave resonator, and a T-TQWT.
The following few posts will show how to use the program, and what to expect.
Before I forget, let's thank Marshal Leach, Richard Long, and Tom Danley. They did all the real work.
The majority of the math I used can be found here: http://users.ece.gatech.edu/~mleach/.../HornPaper.pdf
Thanks go out to David McBean as well. Without his program there would be no need for this.
The Open Office file is a little outdated, but I hope to have it updated to the current build soon.
Easy Horn v8ca1 Excel.zip 37.216796875k . file
Easy Horn v5c OpenOffice.zip 40.0634765625k . file
