AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › The NEW Gaming Headset/Headphone Topic! (REQUEST STICKY PLZ)
The NEW Gaming Headset/Headphone Topic! (REQUEST STICKY PLZ) - Page 164
post #4891 of 5179
Originally Posted by Raven Crimson View Post
That single 3.5mm cable has three 'stripes', left channel, right channel, and mic. Since the mic is integrated to the headset, it's just like the A40s, in which they only need to be hooked up to the Mixamp with one plug. The Y cables are for everything else.
Ok, that makes sense if it's a 4-pole. What's weird is that the Y-cable they provide has male ends. Shouldn't it have female ends to use it with other headsets?
post #4892 of 5179
I picked up the Astro A40 2013 editions over the weekend. I've enjoyed my 5.8 mixamp/Senn PC360 combo for a while now...while it sounds good the I've always suspected the wireless RX unit just doesn't drive the headset well enough to get a full sound over long period of play (for obvious reasons, the RX unit is very small and battery powered) so I figured I'd see what improvements if any Astro had made to their 2011 mixamp/a40 wired offering.
Pros: The sound, particularly at low frequencies is much improved! The bass has resonance without being overpowering and there is no distortion during bass heavy sequences like explosions like there was with past A40 headsets (based on my experience). I plugged my PC360s into the 2013 mixamp and while it sounded fuller than with the 5.8 mixamp, it definately leaned towards the brighter side of the sound spectum. Lows were present but lacked resonance, the new A40s actually have sum 'thump' which I haven't heard in a gaming headset without distortion or covering up the brights in...well...never!
Cons:
  • The headset itself is still extremely uncomfortable for me. Just looking at the A40s next to the PC 360s you can see the earcups on the A40s are significantly smaller. For some reason they really clamp to the sides of your head and the foam bumpstop on top presses into the top of your head. I tried exteneding the earcups to various lengths and the only way to make them slightly comfortable is to extended them to the point where the top isn't resting on your head, which makes the earcups slide around a bit. The PC 360s on the other hand feel like bedroom slippers for you ears, most comfortable headset I've ever worn hands down
  • The EQ button is a neat feature, but I found most of the modes lacking. 'Pro' is brights only (almost no low frequency sounds). Media was to bass heavy. Sport was actually pretty good but makes dialog a little echoey. I just leave it on 'Core'
  • They got rid of the battery pack, which I thought was a great feature and eliminated the need for one plug stretched from the 360 or a wall plug while gaming.
Overall it's all about the sound for me, and in that regard the new A40s are a winner! I have also experienced multiple issues with several PC360 headsets and mic feedback while using the mixamp in the past...so hopefully this will resolve that issue.
I just need to break these puppies in so I can wear them for more than 2 hours at a time...maybe use the old formulanerd wash the earpads and foam bumpstop on the headband trick ;-)
Edited by slyderulz - 10/25/12 at 5:59am
post #4893 of 5179
Originally Posted by jasnmb View Post
yes, I've tried that. I also tried plugging into every other usb port on other devices/laptops that I have. I even tried moving the PS3 to another room, powering off my wireless phones, etc. I still get the same hum at the same volume. I've also tried every combination of volume changes/muting on the decoder box and inline controller, and playing around with every sound and mic setting I can find on the PS3, and using a different USB cable. Nothing I've tried will affect volume of the hum.
Has anyone else with the newer 720 decoder (the one that uses USB for power) had any luck reducing the hum? maybe I need a USB ground loop isolator (if such a thing exists)?
I forgot to mention this... are you plugging the headset directly into a wall instead of plugging it into a powerstrip? I remember getting noise by having the USB charger plugging into a powerstrip. When I went directly to the wall outlet, the mild hum/background noise was gone.
post #4894 of 5179
yes I did try plugging that into a usb-to-outlet adapter and then plugging that into two different wall outlets as well as different powerstips... nothing would affect the buzz.. there are a few reviews on amazon that mention the buzz also.
I've already returned them and will probably just get the mixamp when it comes back in stock + the KSC75 for now. That is unless someone can convince me that getting the DSS2 + a better headphone is the better bang for the buck. but the mixamp seems the safer way to go for me.
post #4895 of 5179
I have the DSS2/X12 combination. It's a budget combination but I've been extremely happy with it. Of course, you're going to deal with a ton of wires though.
But if the Mixamp fits your budget well, go for it.
post #4896 of 5179
Anyone possible interested in selling their Astro 5.8 mixamp, or know where I can pick one up ? Looking to go with a pc360 astro combo. Currently have Tritton Ax720, and they have incresed by kd by 5 points in past 2 weeks. That is pretty significant when you consider I have 11 full days logged into the multiplayer. Its a lot harder to raise, then it is to have it go down.
post #4897 of 5179
Does anyone know if there is a wireless headphone (or headset) that can connect to a transmitter box to hard-wire a stereo analog output from a receiver, mix-amp, etc.., (like Logitech, TB, etc..) but also switch on the fly (ideally with button on the earcup) to Bluetooth AD2P audio mode? My son spends about 1/2 his time online playing Minecraft on a PC laptop, and the other 1/2 on an Xbox or TV. The Xbox or TV could be done wireless w/ any wireless headphone's tx box, but it would be great if the same wireless headphones (or headset, ideally) could also work w/ bluetooth on his laptop.
post #4898 of 5179
I believe the TB XP500 does this.
post #4899 of 5179
I'm pretty sure the PX5s do this too. They have bluetooth support anyway, and I have gone from playing to answering my phone on the headset, so I'd think the same would work with a bluetooth PC connection.
post #4900 of 5179
Any recommendations on an upgrade from the Turtle Beach PX5? They're 2.4GHz, so they have static now and then, audio drops and now that I have home automation, they interfere with my Z-Wave devices. I'd like to upgrade, not sure if there is an upgrade though. Any ideas? Help!!! smile.gif
post #4901 of 5179
I suggest you go with what Daekwan recommends. I had problems with the 2.4 GHz headphones and now with the XP400s, I don't experiences any interference at all.
Originally Posted by Daekwan
That said, I'd HIGHLY recommend spending $47 more and getting the XP400s. You wont be sorry!
http://www.amazon.com/Turtle-Surround-Headset-Xbox-360-6304300/dp/B006W41W4Q/ref=sr_1_1?ie=UTF8&qid=1346800322&sr=8-1&keywords=xp400
If you have more money, you can also try the Warheads.
post #4902 of 5179
So today, I was on ebay, and somebody was selling a astro mixamp 5.8 they bought last december, comes in very good condition, all cables, box, etc. Was able to snag it for 81.00. Also, there was another company that had a few Astro 5.8 on sale if anyone is interested. Naturally I had to track down some Sennheiser Pc 360, so I snagged on amazon, overnight for $219. So my question on the 5.8 mixamp. Do they come with a rechargeable battery pack . Which mode is best to play Cod on, with this mixamp. Any suggestions would be awesome. Currently I have been using a set of Tritton Ax720 headphones, which have been pretty good for footsteps. I'm hoping for the increase in price, that this will be much better. The only thing I really didnt like with my 720's is that they are a closed can, and i cant hear myself talk, my wife says i'm pretty loud with them on.
post #4903 of 5179
There is no modes, just a bass boost option on the mixamp. You can purchase a rechargeable battery pack for it. I got mine through Astro but ebay should sell them as well
post #4904 of 5179
Turtle Beach XP500 refurbs $125 @ woot
http://www.woot.com/offers/ear-force-xp500-7-1ch-wireless
post #4905 of 5179
Ordered x2 for my son and I, thanks!
post #4906 of 5179
I have the delta's which are the same thing and seeing that price makes me cry.
post #4907 of 5179
Anyone know if these TB XP500s have a setting for RF channels or something so two base stations can be used in the same house w/ two 360's and not interfere with each other?
post #4908 of 5179
there is a way to pair headsets with the base station.. check the tb knowledge base on their website to put the headset in the mode to do it, that is if each headset isn't automatically matched with base station it came with.
post #4909 of 5179
Anyone know where I can get a Astro Mixamp pro to use with my PC360's ior is anyone here selling? I'm currently using the Tritton AX720 decoder and want to switch to the Astro.
Unfortunately, can't find them for sale anymore online . Should have bought when I had the chance.
post #4910 of 5179
Astro's twitter account keeps telling people they'll be available again Mid-Nov.
post #4911 of 5179
Cool, thanks. I sent them a tweet as well and they responded with that same info. Guess I'll be able to wait a couple of weeks then.
post #4912 of 5179
Your 360s will sound much better when you do this. I was using the tritton mixamp until I found a 5.8 astro mixamp, sound is much better to me
post #4913 of 5179
this thread used to be booming, even with all these new headsets or ip branded headsets it's slow
post #4914 of 5179
So about 2 weeks ago I picked up the Sennheiser Pc 360, and found an astro 5.8 mixamp on ebay. The mixamp was a little scratched up when I received it, so I was a little irritated, however, I cant imaging a better set up without spending crazy money. The soundstage and accuracy is crazy, with sitrep pro, you can tell exactly where the enemy is coming from. There have been times where I whip around 180 degrees, and fire without seeing the enemy, and getting kills. I've never been a great player by any means, but I have increased by kd from 1.15 to 1.25, and this is with 25,000 plus kills, so it takes a bit of time to raise my kd. I have had a 25-0 game, and a 23-0 game back to back nights, and routinely average around 20-5 for the past couple weeks. I'm not saying that these headphones will make everyone a beast, but I cant imagine going back to just playing the sound thru my tv. Definately worth the money.
post #4915 of 5179
The newer headsets really dont do anything better but provide wireless in some cases. Even then its the same names & same players. Invest in a quality, high rated solution, and theres really not much to discuss beyond that. A good friend of mine (Kabob off AVS) once said.. "Buy Once, Cry Once". And I've never gone wrong taking that advice and spending a little bit more to get a much better solution in the long run.
There's really only two things that still interest me. A true wireless solution with no compromises.. and if Sennheiser ever decides to release a new PC370 headset based off the newer 558/598 headphone.
post #4916 of 5179
My Sennheiser HD 650 gaming review is up!
Sennheiser HD650
Sells for $350-$500
Oh, one of the most beloved and well known headphones in the audiophile community. These were my 'dream' headphone since the beginning of my audiophile journey. One I never thought I'd ever buy back then. It's also one of the few headphones that after I learned what sonic quality I wanted in a headphone, didn't think I would personally like. If I had bought them months or years ago, I'm not sure I would've liked them. I tend to prefer a bright, aggressive, bass and treble-centric headphone. The HD650 is known to be the opposite. Dark/warm, relaxed, and smooth, with dulled treble response. You can see why I was very adamant about not ever giving these a chance.
It wasn't until recently that I wanted to venture out and look for something a little different from my normal preferences. An alternative that I'd use whenever I wanted to sit back, and enjoy a soothing sound, with forward mids/vocals that I could watch my TV shows, movies, anime with. Ironically, my secondary can is considerably more expensive than my main can (DT990s) at the time. Lol, Head-fi logic. Well, I went and took the plunge, hoping for the best, but expecting the worst. I thought I would hate them. Really. It was an experiment that would cost me, but one I needed to do at some point, as the HD650 was always that ONE headphone I was always curious about (more than any other).
So what happened? Did I like them? Hate them? To my surprise... I loved them for music, movies, TV, and anime, and liked but wasn't thrilled by them for gaming. Let's get into the sound.
Bass: The lows. Well, this is surprising. They are actually pretty bassy. Not DT990 bassy, but they have a nice, full, bassy sound. I'd say it's between the DT880 and 990 in presence. It's a warm bass, with medium speed. Pretty much ideal for all-rounder headphones with good bass that would please those that like balance and a fun signature. The bass quantity is enjoyable for all crowds, unless you're a pure neutral-head or pure bass-head. I didn't find myself wanting more bass, though they do roll off in the sub-bass, which is typical of most dynamic headphones, something the HE-400 has no problems with.
If I could score the bass, it'd be; Quantity: 7.5, Quality: 8. Just really pleasing bass all around.
Mids: This is the star of the show. And when I say star... I mean, it is absolutely the best interpretation of mids/vocals I have EVER heard on any headphone...EVER. I'm usually fine with mid recession as I tend to prefer bass and treble emphasis, but MAN... once I heard the HD650... it made me see mids in a whole new light. The vocals are so sweet, so upfront, so rich, so haunting! Based on mids alone, I recommend this headphone to ANYONE looking for a headphone that does vocals some amazing justice. The only other headphone that provides really sweet mids that I've heard is the Audio Technica ESW9, but the ESW9 is a closed on ear, with a considerably smaller soundstage, and overly smooth treble, and stuffy sound signature in comparison. The ESW9 is good, but not HD650 good.
The HD598 also has very forward mids, but I felt the lean bass, and thinner sound, made the mids sound unnaturally forward and shouty. The warmth and fullness of the HD650 basically destroyed any chance the HD598 had in a direct comparison. There was no competition. The HD650's mids demolish the HD598's in tone, realism, and richness. The HE400 is often compared to the HD650, and despite my preference for the HE400, the HD650 is clearly the king of mids here. The HE400 has great, INTEGRATED mids, that don't sound pushed back or forward with a realistic tone. That being said, the HD650's forward mids are special. The HD650 clearly wins here. As far as Q701 and HD650's mids, the HD650 wins again. The Q701 has forward mids, but they aren't nearly as full sounding, or as rich.
Long story shot, the mids are godly. If I had to score them: Quantity: 10, Quality: 10. That is perfection, because that's how I feel about the HD650's mids.
Treble: Oh the treble. This is single-handedly the ONLY reason I have put off getting the HD650 for so long. If you read about the HD650, the treble will always be discussed and debated on. Are they too smooth, rolled off, undetailed... veiled? This is a debate that will never end on Head-fi. As a fan of treble sparkle and some emphasis, I was absolutely mortified about hearing what people said of the HD650's smooth, laid back, dull, treble.
So how did they sound to me? Surprisingly, I REALLY liked the treble! I didn't LOVE it. I still do prefer some more sparkle, but as the relaxing alternative to my typical treble emphasized headphones, I didn't find the treble overly smooth or dull on the HD650. Trust me, when your main can is the DT990 which is known for it's SUPER treble emphasis, and compare it directly to the much more reserved and rolled off treble of the HD650, you would tend to notice a huge difference. In all honestly, I really thought the treble on the HD650s was right where it should be for the type of headphone that the HD650 is. Without that treble, I think the HD650 wouldn't sound as rich and 'creamy' as they do. Would I use the HD650s as my ONLY headphone? To be frank, no. They performed well in absolutely everything except genres that desired an aggressive signature. Stuff like metal, and EDM just didn't have the energy on the HD650s. So no, they aren't the perfect all rounders. However, through some vocal dependent tracks, and stuff like movies, TV, and most non-music needs (even gaming), the HD650s are indeed in a very good place. Unfortunately, I tend to listen to EDM and metal more than anything, so the HD650 lost a few points.
To score the treble; Quality: 7, Quantity: 7. If the treble is boosted by a bit, these could be what I'd consider very natural to neutral with a slight emphasis towards bass. I think they'd be less rich overall though, so I personally wouldn't want to touch what makes the HD650 what they are.
Amping: I have the HD650 paired up with the Audio-GD SA-31 which is much more powerful than pretty much any amp most of you use, or would use, so I'm not exactly sure how they'd sound with less power, but I personally felt that they aren't as hard to drive as people make them out to be. They need considerably less power than the DT990/600, and possibly even the DT990/250. I'd say they'd need about as much as the DT990/32 for at LEAST volume level. We know power =/= volume, but it helps. To be clear: they do not need a lot to be driven LOUDLY. I tested them with the Mixamp only, and they can be driven off it loud enough. I didn't test it enough to see how well they're actually driven, but they sounded good. They may be a little thinner sounding, which could actually be a good thing for gaming, as it makes pinpointing sounds a bit easier than the very rich, thick signature the HD650s have with the SA-31.
Okay, so how did they perform for gaming?
Soundstage: I haven't gotten to the specifics of gaming with the HD650s yet, but I'll mention the soundstage first. With and without extra amping the Mixamp, I felt the HD650's soundstage to be medium sized. Not big, and not little. However, I didn't find them to be stellar in terms of depth, so the sense of space for gaming, wasn't as good as I would have hoped. I was always expecting the HD650 to not be the greatest pairing for Dolby Headphone, and my fears were slightly warranted. The front/back depth isn't great. Let's get that out of the way. The width is good, but not close to being the best. The DT990 destroys the HD650 in both depth and width. So how's the air within the soundstage? Well, the problem with the HD650, is that it's a very full sounding headphone. Thick, warm tone tends to make the soundstage seems less airy and smaller. This is one of those times where a thinner/leaner sounding headphone has the advantage, like the AD700/HD598/K701. The HD650 isn't STUFFY like say the ESW9, but that rich tonality doesn't help gamers.
Positioning: Positioning and soundstage tend to go hand in hand, so if the soundstage isn't great, the positional cues will suffer. How did the HD650 fare positional-wise? Well, they were good. Not great, and could obviously be better, but they do their job. I could play something like Black Ops without any problems, though having used headphones much better for soundstage/positioning, I could tell they lacked a bit. I'd put the HD650 just ever so slightly above the DT880 positional wise, but they aren't that much better.
Clarity: You need clarity for soundwhoring in competitive gaming. Despite the laid back treble, I found the natural tone of the HD650 to be very detailed. The forward mids came off very clean and clear, and I felt I didn't miss any sounds. I've heard better overall (even the 990's are better for soundwhoring). The problem is that the HD650 is a very thick sounding headphone. Basically, the issues I explained in the soundstage section is what hurts clarity for gaming purposes.
Comfort: I mentioned that Sennheiser likes their clamp. The HD201, HD280 Pro (!), PC360, and HD598 all have some form of clamp. The HD650 is no different. They do clamp a bit more than I'd personally like, but it's a minor gripe overall. I find the HD650 to be very comfortable overall, and over extending the arms a little, to wear the HD650 slightly loose alleviates the clamp a bit. I've felt better, but not much better. The velours are great. Not too firm, and not too soft. The cups are huge and will fit ears very comfortably. I like the oval shape, which makes them easier to use while laying down compared to circular cups.
Value: The Sennheiser HD650 is a considerably expensive headphone. If your main purpose for getting a headphone is gaming, there are considerably better options for less. If pure audio fidelity, and non-gaming purposes is your main purpose, the HD650 is incredibly hard to beat. Their sound signature is just stellar for most things, save for a few genres, and they're competent for gaming, just not stellar. I personally can't justify owning both the HD650 and HE-400, so I stuck with the HE-400 which is a more energetic, and better equipped for gaming use.
Final Impressions: The HD650 has a very special place in my heart. It took years to finally take the plunge, but I'm VERY glad I did. They have quickly become one of my very favorite headphones. Though their gaming performance isn't as stellar as I would have hoped, it's better than I expected. I absolutely love the HD650 overall, and they have made me see the importance of mids, if even for just non-gaming, non-music use. Movies and TV shows are made for the HD650. Their incredible tonality, rich/full sound, perfect mids are an absolute blessing. Treble is definitely it's weakest aspect of sound, but they aren't veiled, just...reserved.
For gamers looking for all-rounders, these do put up a fight. They're better than the vast majority of headphones I mentioned on this guide in terms of audio fidelity, but in raw performance for gaming, they're outclassed by others costing considerably less.
Final Scores...
Fun: 8
Competitive: 7
Comfort: 8
Edited by Raven Crimson - 11/12/12 at 10:23am
post #4917 of 5179
If I had my main account back, I'd update the first post (along with the main review post a few posts down), but they won't give it back. I'd do a new Gaming Headphone Thread (Version 3) here on AVS if you guys want, with a link to this one. I will only do it if you guys deem it necessary. It will mirror the Head-fi thread in terms of reviews. Though obviously different as it's AVS, lol. The main benefit is having an updated first post. The current one is VERY old and outdated.
http://www.head-fi.org/t/534479/mad-lust-envys-headphone-gaming-guide-updated-11-12-12-sennheiser-hd650-added
That one is a LOT more active, including updated first post.
Problem is that AVS tends to look for gaming headsts, while head-fi looks for audiophile headphones that would be good for gaming.
BTW, I'm Mad Lust Envy/Shin CZ, in case people haven't figured that out yet.
Edited by Raven Crimson - 11/12/12 at 10:18am
post #4918 of 5179
and I thought my TB Deltas were expensive lol.... I bet those sound great though
post #4919 of 5179
I hope so.
I bought a set of Astro A40's to try out, unfortunately you need a Y splitter cable that's sold seperately to use your own headset. I cant really test my PC360's until i get the cable but I like the Mixamp way better than the tritton box already.
post #4920 of 5179
I hope so.
Stranger who I've never talked to before, ever, about this:
Here's a link to the cable you can use until Astro gets their sh*t together and puts it back on their site.
http://www.amazon.com/Headset-Buddy-01-PC35-PH35-Smartphone-Blackberry/dp/B002SK66OY/ref=sr_1_1?ie=UTF8&qid=1352751385&sr=8-1&keywords=headset+buddy
  Back to Forum: Xbox Area
