Originally Posted by jasnmb
Hopefully the next xbox does away with that silly headset wire to the controller. I supposed it saves MS money when bundling the xbox with a short wired headset, vs a wireless one or a long cable to connect directly to the xbox. But aside from that, ideally they would switch to standard usb for wired chat, and bluetooth for wireless.
Hopefully. They've kind of dug themselves into a corner though. If they want to go open spec they have to break compatibility with their current gear, or build in redundant hardware to cover the BC for accessories. I think they like it closed so they can overcharge, its just what they do.
Unless Sony moves to proprietary wireless specs....I'm fairly certain all the PS3 compatible headsets should work 100% going forward.
I did do that a couple of times back when I still had my Fiio E7&E9 -- but the game of "disconnect E9 from PC, carry to media room, hook up line out from Mixamp to line in on E9, go find an extension cord so I can actually plug in the E9 and have it sit close enough I can reach the volume control..." was more hassle than I wanted to deal with on a regular basis. (waah, waah, I want my entertainment NOW
