Interesting. Regardless of whether I have Hardware Acceleration checked or unchecked, the only setting that gives me full resolution is None. No big deal, I can leave it at none.
Just going through the system with the DVE Blu-Ray setup disk and have noticed another problem...blacks and whites are crushed. All above white and below black information is missing. I found the setting in the Intel control panel for the video range and tried all the available settings (Default, Full, and Limited) but none of these fixed the issue. Also tried all of these settings with video type set to Ycbcr and didn't help either. Doesn't seem to be any way to get full video range with the Intel HD 3000 graphics setup.
So these are my issues. I've found workarounds for most of them but if anyone is seeing any of these, you're not alone:
1. Bob deinterlacing when usigng any of the TMT5 deinterlacing options. Workaround - set deinterlacing to none.
2. TMT5 crashing when playback is stopped (using MC player plugin) if auto refresh switching is enabled. External player is fine. Workaround - set Media Browser to launch external player.
3. Crushed whites/blacks. No workaround (but low impact since your not really supposed to see this information anyway)
Probably some others I forgot. This is so close to being the perfect solution for me so I hope some of these issues get addressed with future releases
