Anyone having issues with newer MKV files, such as new episodes of Spartacus and The Walking Dead?
When attempting to play these newer episodes, I encounter the error, "Unsupported file type."
My current TMT5 version is 5.3.1.146, however, I tested versions 120, 144, and 145 with the same error given.
Using mediainfo on episodes 1 and 11 from season 3, the only difference between the two is that for episode 1, the writing application shows that mkvmerge 5.8.0 (no sleep/pillow) was used,
where as on episode 11, mkvmerge 6.0.0 (coming up for air) was used. The same application is used for the newer episodes of Spartacus season 3.
The mkvs play in media player and VLC but not TMT5, however files written pre mkvmerge 6.0.0 play fine in all three.
Normally it would be an issue, its that people in my house can't launch these files using Media browser and need to resort to using folder pathways. Not the prettiest method.
Anyone experience a similar issue? Thanks for any comments and suggestions.
