Posted: 08 Oct 2010 at 11:56pm
TMT3 with SimHD will play movies natively from Win7 Media Center Movie Library by creating a folder BDMV alongside with VIDEO_TS, for example, STAR_TREK as primary folder, then two subfolders BDMV and VIDEO_TS. After clicking on a boxcover Win7 Media Center will blankout momentarily then load TMT3 with SimHD activated, you also play the movie side-by-side.
Note for best performance, the movie needs to be run from the harddrive unless you have a high performance computer that can run the DVD from the DVD drive.
Back to Top
akkadian50001 View Drop Down
Members Profile
Find Members Posts
Posts: 4 Post Options Post Options
Post Reply
Quote akkadian50001
Edit Post
Quote akkadian50001 Quote Post ReplyReply Direct Link To This Post Posted: 09 Oct 2010 at 12:02am
I want to comment on my previous post of adding BDMV, that I did pay the $50 extra for MyMovies Collection Managerc feature of being able to change under Tools, Options then External Players the DVD File Structure (VIDEO_TS) setting to TotalMedia Theatre 3. You can have a sort of dead end with MyMovies (you have to submit every single movie you have that is not in their collection, for example, personal family DVD movies can't be added to their database), and you can't see the boxcover under My Movies (plug-in under Media Center).
Since all my movies and personal boxcovers are under the Win7 MCE default Movie Library, I really just wanted TMT3 with SimHD to open up all my DVDs, thus adding BDMV along with VIDEO_TS was the solution that worked for me.
Back to Top
ArcSoft_Jason View Drop Down
Members Profile
Find Members Posts
Admin Group
Admin Group
Posts: 4954 Post Options Post Options
Post Reply
Quote ArcSoft_Jason
Quote ArcSoft_Jason Quote Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 3:40pm
Originally posted by HETUZAR
Dear Friends
Is there any chance to add support for BDMV Folder Structures in MediaCenterPlugin?
The main TMT3 is able to play BDMV, but it's not supported in MediaCenterPlugin.
It's a bit tough to figure out what you mean, but as akadian50001 noted the MCE plug in does support this if you use the Movie Library (or similar 3rd party applications) to select the folder structure and pass it along to the player plug-in.
Back to Top
Members Profile
Find Members Posts
Post Reply
Quote akkadian50001
Edit Post
Quote akkadian50001 Quote Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 12:19pm
Exactly, after installing TMT3 with SimHD, all you have to do is create BDMV folder right next to VIDEO_TS (this is for playing DVD vobs, DVDs from your collection on harddrive), and then when you use the default Win7 Media Center My Movies, you click on a boxcover, and TMT3 plug-in will load wait a few seconds and you are now playing your DVD upscaled (you can select various SimHD options), like info, split screen, etc., and adjust those settings.
The best settings for me is using CPU (E5300 Acer Media computer) instead of ATI Stream (since I have an ATI 5770 card) and having Dynamic Lights either off or set to the lowest level 1. Sharpness I have at 2.
Back to Top
Members Profile
Find Members Posts
Post Reply
Quote akkadian50001
Edit Post
Delete Post
Quote akkadian50001 Quote Post ReplyReply Direct Link To This Post Posted: Today at 7:34pm
Upgraded to TMT5, all functionality using TMT3 described above doesn't work anymore; weird.
TMT5 doesn't see any of my DVD collection that is on the harddrive? whereas TMT3 did immediately from Win 7 Media Center 'default' My Movies
disappointed; it did however install TMT5 alongside TMT3, i plan to uninstall TMT5 soon, don't want the functionality to continue to be broken
