AVS › AVS Forum › HDTV › HDTV Technical › Using Taps (5-1000MHz) with Directv?
post #1 of 2
I want to run the following sources: tv(comcast ota), directv receiver, and cable modem. I have a run that I know is comcast, and another that will be dtv. I'd like to run one cable from the two inputs and then split them at their appropriate inputs. Do I have to run the directv cable separately or can it travel over the same cable? I believe I am using RG-6, but im not sure exactly how to know.
What is the best way to run the cable? Will these style taps kill the directv signal?
THanks!
post #2 of 2
DirecTV and your Comcast can't share the same cable or similar equipment. You'll need a separate drop for DirecTV. And, assuming you're using SWM equipment, you'll need SWM "splitters" to feed the different (up to 8 tuners) receivers. Ordinary cable TV equipment won't work.
Here's a good explanation of how it all works: http://www.youtube.com/watch?v=WkpahQBYFYc
  Back to Forum: HDTV Technical
