Hello All-
Questions for you guys. In my bedroom I currently have a plasma on my wall and was thinking of replacing it with a projector/electric screen combo for aesthetics.
The issue I am having is that the room is small, its a timber loft so ceilings are 11'+ high. My plan was to mount a projector to the beam and Keystone correct the picture.
Is there an easy way to figure out if this will even work?
Ray
Ray
