AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › DIY Constant Height › Looking for Fixed Masking Advice
post #1 of 5
Looking for some advice on how to mask around my screen material. Take a look at the attached photo. I will be stapling Center State XD to the opening in the middle and then building masking panels for the top, middle, and 2 sides to create the 2.35:1 screen. I am looking for advice on what to build these fixed panels out of. They will not be removed, except for an emergency. Should I use foam or plywood. I know I will wrap in velvet for a total velvet wall. Should I build one of the sides with a hinge for easy access. Or should I make them removable? Really looking for some advice here.
And also, what should I incorporate into these fixed panels to allow for the placement for removable side panel for 16:9 masking. I am fine with manual removable panels. I was planning to go with neodymium magnets, but maybe there is a better option.
I am really excited to get my room done and am really looking for some advice here to finish up my screen wall. In our old house I just mounted a screen on the wall and put the speakers on the side, so this transparent false wall is new to me.
David
post #2 of 5
Your wall looks similar to mine with one advantage, it's not curved. So much easier to make removeable framing like I did.
I made my framing out of PVC wood ripped down to 1 inch strips and fitted into place with friction. You can you use convetional wood but look for something that won't easily warp, actually for this reason I may recommend the PVC wood as well. Just make cross bracing I did.
You can see how I went about it starting on this page of my thread. Good luck.
http://www.avsforum.com/avs-vb/showt...020419&page=23
post #3 of 5
Is velvet material typically acoustically transparent to let bass through from a woofer?
post #4 of 5
Actually another person on the forums recently used velvet material to do just that. He did some basic stuff to see if the material should be AT enough and it seems like it is. In paticular he has no complaints with the material in front of his subwoofer. Here is a link to his thread page where he is covering this. Starts with post 1383.
http://www.avsforum.com/avs-vb/showt...683853&page=47
post #5 of 5
Totally. Sub bass frequencies are not stopped by much given their wavelengths which are long, so tend to pass through pretty much any type of material.
  Back to Forum: DIY Constant Height
