AVS › AVS Forum › Video Components › Video Processors › New DVDO iScan Duo [2.30 firmware released]
New DVDO iScan Duo [2.30 firmware released] - Page 3
post #61 of 83
It takes my unit a little bit of time to make the transition as well. Can't say as I've been shocked though. Actually, doesn't bother me in the least.
post #62 of 83
It is the same with the Edge. I guess it gets nastier the bigger your screen.
A fix sure would be welcome though.
post #63 of 83
It would be nice if AnchorBay could comment on the green flashes, it doesn't look nice when you are trying to present a movie to guests in your HT.
post #64 of 83
Originally Posted by SJHT View Post
Can this thread be merged with the other duo thread? Or are we going to have a separate thread for each firmware? SJ
I agree I only just noticed this thread. I'm subscribed to the other and it was by chance by visiting the video processor thread.
post #65 of 83
Flashing green? I don't see it with my RS1. I supose my projector must blank out during any flashing. All good with my Duo but I am still on 2.0 firmware so maybe that has something to do with it.
post #66 of 83
When I connect the the DVDO control panel up to the DUOand get the reading from the DUO the CMS values aren't there. Say for instance I calibrate using the DUO and go back to look at the values in on the CMS page there are no values present. Is this an indication that the DUO is not saving the settings?
post #67 of 83
Installed 2.3. Still no green flash with my RS1.
post #68 of 83
Originally Posted by HogPilot View Post
So does the new firmware only allow 3D passthru - i.e. no manipulation (scaling, CMS, etc) of the 3D signal? Or can you process 3D too?
I am considering a DVDO DUO for my Mitsubishi DLP and would like to use it with 3D video as well (to increase the brightness, at the very least)... I haven't been able to find an answer anywhere, but I'd also like to know the answer to this question. Are there any calibration settings accessible while viewing 3D video, or is it just pass-through. I suppose it wouldn't be the end of the world if no calibration was available, since I could always set the brightness higher on the TV itself, but I'd like to utilize the same calibration (+ extra brightness) on 3D source material as well. Thanks!
post #69 of 83
Quick question for Duo owners. If you set audio output to "Optical" is audio routed out over both optical and coax. I imagine this has to be the case, but the online user manual doesn't say so.
post #70 of 83
Checkerboard did or does not pass properly through my Duo to my 82837. Therre is a bad jitter. If you go straight to the set from your 3 d source you don't get it. It could just be my uint I don't know.
post #71 of 83
SimplayLabs/DVDO have answered for me. Audio is routed over both at the full bitrate from source, but not over HDMI at same time as well.
post #72 of 83
FYI: Got a new Duo and it came installed with firmware 2.32
post #73 of 83
The web site still has 2.30 - DUO_230_079a.abt
post #74 of 83
Hmmm.... I seem to be having an issue. Duo was running great and I had not updated the firmware for about 9 months or so. Figured to much time had probably gone by so updated the firmware last week to 2.32.
Now my HTPC will no longer Sync with the duo. The initial start up screen shows up fine, but when Windows loads and tries to switch to 720p the screen just flashes... you see the image for perhaps a second and then gone... then back... then gone... occasionally the image would stabilize for about 10 seconds (and I mean occasionally) and the Info screen would show the correct input... but then it would switch to "unsupported signal" and the flashing starts all over again.
Perhaps I should download 2.30 and see if that fixes it.
post #75 of 83
Originally Posted by mdehoog View Post
Thanks for helping me beta test this thing! You're right, but the bug lies in Anchor Bay's serial automation protocol documentation. The docs say that:
- Mosquito NR = C8
- Detail Enhancement = C9
- Edge Enhancement = CA
But thanks to your attention to detail I've found that it's actually:
- Detail Enhancement = C8
- Edge Enhancement = C9
- Mosquito NR = CA
...which means that all of the above controls were broken (were actually changing the wrong parameters).
Here's a fixed release:
http://www.cellophanesoftware.com/is...panel_v0.5.zip
I haven't done a firmware update on my Duo because of all settings being reset. Today I began looking through the forum to see if there was anything extraordinary in the firmware to coax me into doing it. In that process I stumbled across this thread with your software to backup the settings and would like to use it, but feel a little nervous about it as there doesn't seem to be much information in here abou how to do it. Is this quite easy? Do I only need a USB to serial cable and this program and the .net program. Is there anything else I need? Has this been superseded by anything since this thread was current?
post #76 of 83
Current verson is 0.5, works perfectly.
Does not use windows installer, just unzip and run
Make sure Duo is on and connected to a display via hdmi1 and or 2
You need a USB to serial RS232 adapter unless your PC has an RS232 output.
Search AVS for RS232 or serial here:
http://www.avsforum.com/avs-vb/showt...8#post21352928
There are bargains on Amazon and Ebay
Not all adapters work, mine uses a Mostek chip and works.
The app is intuitive as are the menus, you will learn it in no time
Go for it.
Also be advised that Tom Hufman is planning to add some of these controls to his ChromaPure calibration software to enable Duo CMS adjustments during calibration.
post #77 of 83
I also would suggest:
http://www.usbgear.com/USB-to-Serial.html
They work on almost anything, Best on the market.
Rew
post #78 of 83
Thanks for the tips. I think I'll try it
post #79 of 83
I'm trying to backup my CMS settings done via Calman to try out different targets.
I'm using Control Planel 0.5 and unfortunately all CMS tab entries remains at 0.
Console logs shows the following:
Code:
INFO: Query 'Input Select' result: Auto (0)
INFO: Query 'PReP 480p/576p' result: Off (1)
INFO: Query 'PReP 1080p' result: Off (1)
INFO: Query 'Deinterlacer Mode' result: Auto (6)
INFO: Query 'Input Color Space' result: Auto (0)
INFO: Query 'Input Colorimetry' result: Auto (0)
INFO: Query 'Input Video Level' result: Computer (2)
WARNING: Timeout querying 'Input Chromaticity', retrying
INFO: Query 'Input Chromaticity' result: Auto (0)
INFO: Query 'Hot Plug Source' result: Auto (0)
INFO: Query 'Audio Input' result: HDMI (1)
INFO: Query 'Input Aspect Ratio Presets' result: 16:9 Full Frame (1)
INFO: Query 'Mosquito Noise Reduction' result: Off (0)
INFO: Query 'CUE Correction' result: Off (0)
INFO: Query 'Output Select' result: HDMI 1 (1)
INFO: Query 'Output Video Format' result: 1080p60 (13)
INFO: Query 'Frame Lock Mode' result: Auto (0)
INFO: Query 'Display Aspect Ratio' result: 16:9 (1)
INFO: Query 'Output Color Space' result: YCbCr 4:4:4 (3)
INFO: Query 'Output Colorimetry' result: Auto (0)
INFO: Query 'Output Video Level' result: Video (1)
INFO: Query 'Output Chromaticity' result: RGBs/709 (1)
INFO: Query 'Output HDCP Mode' result: Auto (2)
INFO: Query 'Audio Output' result: HDMI Audio (2)
INFO: Query 'Auto Wakeup' result: Mode 1 (1)
INFO: Query 'Menu Timeout' result: 40 seconds (1)
INFO: Query 'Day/Night Profile' result: Day (0)
INFO: Query 'Info Screen' result: Off (0)
INFO: Query 'Test Pattern' result: Off (0)
INFO: Query 'Game Mode' result: False (0)
INFO: Query 'Input HDCP Mode' result: True (1)
INFO: Query '1:1 Frame Rate' result: False (0)
INFO: Query 'Second Output' result: False (0)
INFO: Query 'Auto Standby' result: True (1)
INFO: Query 'Audio Delay' result: 0 (0)
WARNING: Could not parse decimal: 1.000
INFO: Query 'Horizontal Stretch' result: 0 (1.000)
INFO: Query 'Vertical Stretch' result: 0 (1.000)
INFO: Query 'Horizontal Shift' result: 0 (+0)
INFO: Query 'Vertical Shift' result: 0 (+0)
INFO: Query 'Zoom' result: 0 (1.000)
INFO: Query 'Brightness' result: 0 (+0)
INFO: Query 'Contrast' result: 0 (+0)
INFO: Query 'Saturation' result: 0 (+0)
INFO: Query 'Hue' result: 0 (+0)
INFO: Query 'Y/C Delay' result: 0 (+0)
INFO: Query 'Detail Enhancement' result: 25 (+25)
INFO: Query 'Edge Enhancement' result: 0 (+0)
WARNING: Could not parse decimal: 5.0
INFO: Query 'Underscan' result: 0 (5.0)
INFO: Query 'Border Level' result: 0 (0)
INFO: Query 'Mask Level' result: 2 (2)
WARNING: Could not parse decimal: -0.0846
INFO: Query 'Color Gamut - Red-x' result: 0 (-0.0846)
WARNING: Could not parse decimal: +0.0062
INFO: Query 'Color Gamut - Red-y' result: 0 (+0.0062)
WARNING: Could not parse decimal: +0.0000
INFO: Query 'Color Gamut - Red-Y' result: 0 (+0.0000)
WARNING: Could not parse decimal: +0.0154
INFO: Query 'Color Gamut - Green-x' result: 0 (+0.0154)
WARNING: Could not parse decimal: -0.1030
INFO: Query 'Color Gamut - Green-y' result: 0 (-0.1030)
INFO: Query 'Color Gamut - Green-Y' result: 0 (+0.0000)
WARNING: Could not parse decimal: -0.0277
INFO: Query 'Color Gamut - Blue-x' result: 0 (-0.0277)
WARNING: Could not parse decimal: +0.0086
INFO: Query 'Color Gamut - Blue-y' result: 0 (+0.0086)
INFO: Query 'Color Gamut - Blue-Y' result: 0 (+0.0000)
WARNING: Could not parse decimal: +0.0264
INFO: Query 'Color Gamut - Cyan-x' result: 0 (+0.0264)
WARNING: Could not parse decimal: -0.0037
INFO: Query 'Color Gamut - Cyan-y' result: 0 (-0.0037)
INFO: Query 'Color Gamut - Cyan-Y' result: 0 (+0.0000)
WARNING: Could not parse decimal: -0.0092
INFO: Query 'Color Gamut - Magenta-x' result: 0 (-0.0092)
WARNING: Could not parse decimal: +0.0245
INFO: Query 'Color Gamut - Magenta-y' result: 0 (+0.0245)
INFO: Query 'Color Gamut - Magenta-Y' result: 0 (+0.0000)
WARNING: Could not parse decimal: -0.0335
INFO: Query 'Color Gamut - Yellow-x' result: 0 (-0.0335)
WARNING: Could not parse decimal: -0.0520
INFO: Query 'Color Gamut - Yellow-y' result: 0 (-0.0520)
WARNING: Could not parse decimal: -0.0297
INFO: Query 'Color Gamut - Yellow-Y' result: 0 (-0.0297)
WARNING: Could not parse decimal: +0.0026
INFO: Query 'Color Gamut - White-x' result: 0 (+0.0026)
WARNING: Could not parse decimal: +0.0009
INFO: Query 'Color Gamut - White-y' result: 0 (+0.0009)
INFO: Query 'Color Gamut - White-Y' result: 0 (+0.0000)
WARNING: Could not parse decimal: -0.0731
INFO: Query 'Grayscale - Red - 0 IRE' result: 0 (-0.0731)
WARNING: Could not parse decimal: -0.1731
INFO: Query 'Grayscale - Red - 10 IRE' result: 0 (-0.1731)
WARNING: Could not parse decimal: -0.2731
INFO: Query 'Grayscale - Red - 20 IRE' result: 0 (-0.2731)
WARNING: Could not parse decimal: -0.3731
INFO: Query 'Grayscale - Red - 30 IRE' result: 0 (-0.3731)
WARNING: Could not parse decimal: -0.4731
INFO: Query 'Grayscale - Red - 40 IRE' result: 0 (-0.4731)
WARNING: Could not parse decimal: -0.5731
INFO: Query 'Grayscale - Red - 50 IRE' result: 0 (-0.5731)
WARNING: Could not parse decimal: -0.6731
INFO: Query 'Grayscale - Red - 60 IRE' result: 0 (-0.6731)
WARNING: Could not parse decimal: -0.7731
INFO: Query 'Grayscale - Red - 70 IRE' result: 0 (-0.7731)
WARNING: Could not parse decimal: -0.8731
INFO: Query 'Grayscale - Red - 80 IRE' result: 0 (-0.8731)
WARNING: Could not parse decimal: -0.9731
INFO: Query 'Grayscale - Red - 90 IRE' result: 0 (-0.9731)
WARNING: Could not parse decimal: -1.0731
INFO: Query 'Grayscale - Red - 100 IRE' result: 0 (-1.0731)
INFO: Query 'Grayscale - Green - 0 IRE' result: 0 (-0.0731)
INFO: Query 'Grayscale - Green - 10 IRE' result: 0 (-0.1731)
INFO: Query 'Grayscale - Green - 20 IRE' result: 0 (-0.2731)
INFO: Query 'Grayscale - Green - 30 IRE' result: 0 (-0.3731)
INFO: Query 'Grayscale - Green - 40 IRE' result: 0 (-0.4731)
INFO: Query 'Grayscale - Green - 50 IRE' result: 0 (-0.5731)
INFO: Query 'Grayscale - Green - 60 IRE' result: 0 (-0.6731)
INFO: Query 'Grayscale - Green - 70 IRE' result: 0 (-0.7731)
INFO: Query 'Grayscale - Green - 80 IRE' result: 0 (-0.8731)
INFO: Query 'Grayscale - Green - 90 IRE' result: 0 (-0.9731)
INFO: Query 'Grayscale - Green - 100 IRE' result: 0 (-1.0731)
INFO: Query 'Grayscale - Blue - 0 IRE' result: 0 (-0.0731)
INFO: Query 'Grayscale - Blue - 10 IRE' result: 0 (-0.1731)
INFO: Query 'Grayscale - Blue - 20 IRE' result: 0 (-0.2731)
INFO: Query 'Grayscale - Blue - 30 IRE' result: 0 (-0.3731)
INFO: Query 'Grayscale - Blue - 40 IRE' result: 0 (-0.4731)
INFO: Query 'Grayscale - Blue - 50 IRE' result: 0 (-0.5731)
INFO: Query 'Grayscale - Blue - 60 IRE' result: 0 (-0.6731)
INFO: Query 'Grayscale - Blue - 70 IRE' result: 0 (-0.7731)
INFO: Query 'Grayscale - Blue - 80 IRE' result: 0 (-0.8731)
INFO: Query 'Grayscale - Blue - 90 IRE' result: 0 (-0.9731)
INFO: Query 'Grayscale - Blue - 100 IRE' result: 0 (-1.0731)
INFO: Query 'Grayscale - White-x - 0 IRE' result: 0 (+0.0000)
WARNING: Could not parse decimal: -0.0000
INFO: Query 'Grayscale - White-x - 10 IRE' result: 0 (-0.0000)
INFO: Query 'Grayscale - White-x - 20 IRE' result: 0 (-0.0000)
INFO: Query 'Grayscale - White-x - 30 IRE' result: 0 (-0.0000)
INFO: Query 'Grayscale - White-x - 40 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-x - 50 IRE' result: 0 (-0.0000)
INFO: Query 'Grayscale - White-x - 60 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-x - 70 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-x - 80 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-x - 90 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-x - 100 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-y - 0 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-y - 10 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-y - 20 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-y - 30 IRE' result: 0 (-0.0000)
INFO: Query 'Grayscale - White-y - 40 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-y - 50 IRE' result: 0 (-0.0000)
INFO: Query 'Grayscale - White-y - 60 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-y - 70 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-y - 80 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-y - 90 IRE' result: 0 (+0.0000)
INFO: Query 'Grayscale - White-y - 100 IRE' result: 0 (+0.0000)
WARNING: Could not parse decimal: -0.0162
INFO: Query 'Grayscale - White-Y - 0 IRE' result: 0 (-0.0162)
WARNING: Could not parse decimal: -0.0395
INFO: Query 'Grayscale - White-Y - 10 IRE' result: 0 (-0.0395)
WARNING: Could not parse decimal: -0.0733
INFO: Query 'Grayscale - White-Y - 20 IRE' result: 0 (-0.0733)
WARNING: Could not parse decimal: -0.1239
INFO: Query 'Grayscale - White-Y - 30 IRE' result: 0 (-0.1239)
WARNING: Could not parse decimal: -0.1923
INFO: Query 'Grayscale - White-Y - 40 IRE' result: 0 (-0.1923)
WARNING: Could not parse decimal: -0.2793
INFO: Query 'Grayscale - White-Y - 50 IRE' result: 0 (-0.2793)
WARNING: Could not parse decimal: -0.3858
INFO: Query 'Grayscale - White-Y - 60 IRE' result: 0 (-0.3858)
WARNING: Could not parse decimal: -0.5122
INFO: Query 'Grayscale - White-Y - 70 IRE' result: 0 (-0.5122)
WARNING: Could not parse decimal: -0.6590
INFO: Query 'Grayscale - White-Y - 80 IRE' result: 0 (-0.6590)
WARNING: Could not parse decimal: -0.8269
INFO: Query 'Grayscale - White-Y - 90 IRE' result: 0 (-0.8269)
WARNING: Could not parse decimal: -1.0162
INFO: Query 'Grayscale - White-Y - 100 IRE' result: 0 (-1.0162)
INFO: Query 'Product Name' result: iScan Duo (iScan Duo)
INFO: Query 'Version Number' result: 2.32B0.79k (2.32B0.79k)
It looks like the program may have regional issues figuring out decimal numbers. Using Windows7 and my regional setting is set to use comma (,) as decimal symbol.
Any idea?
post #80 of 83
Assume you have 'CMS' selected under the 'Save' tab?
Also assume you are using 'Backup both CMS Profiles' under 'File' tab?
post #81 of 83
- Yes
- Doing so results in a XML with all values at 0
post #82 of 83
- Yes
Perhaps change your computer to the usual decimal point may prove or disprove your theory?
post #83 of 83
yay, changing decimal separator to dot (.) solved the issue. The program can now read all CMS fields correctly. Thanks for the pointer.
  Back to Forum: Video Processors
