I purchased 5 of the :
http://www.parts-express.com/pe/show...number=276-412
To build my 5 channel theater speaker set.
Everything I read tells me to cross them over no less than 2500Hz
I purchased 20 of the :
http://www.parts-express.com/pe/show...number=299-246
Which I am told start to fall apart higher than 250hz
I am looking at building a WWMTMWW speaker both in horizontal for the center channel and Vertical for the other 4.
I understand the logistics of my plan and I appreciate those that say I am insane with my plan lol.
I have a cabinet builder with tons of zest, I plan on using Solen here in Canada to design my 3 way crossovers....BUT
I need a good midrange choice and I need someone to let me know what the best sealed enclosure volume I should use for the woofers (each) I can do the math otherwise.
So I am looking at these midrange and I`d like to stay around 25-35 dollars per midrange..
http://www.parts-express.com/pe/show...number=264-828
or
http://www.parts-express.com/pe/show...umber=264-1058
or
http://www.parts-express.com/pe/show...number=297-434
My eyes are crossing in looking at specs.
I am using an Acurus 200x3 and matching (wattage) NAD for the rear channels.
I have wicked subs so I really don`t need less than 80Hz for the bass on the woofers......I`m kind of wondering if I could stretch the woofers as high as 500Hz without too much issue if need be.
Sealed enclosure size for each woofer and a midrange match...
Thoughts? I am open to some ideas even outside my price range, cause this is my last set of speakers I am buying.
famous last words....
Jeff
or
or
Jeff
That said I have a couple of suggestions for you that are near to your budget:
. Have you considered an AT screen? Only $200 or so from Seymour AV and it would provide a far more convincing soundstage...you'd be surprised.
