I've been trying out Soho's easy TH spreadsheet with a TD10S to see what I can get. It seems really easy until I get to the point of determining max excursion and then I always seem to go over with very little watts.
I attach my results to date. My question is - What do I need to change to get it right? Very much an amateur with horn design so I may be missing the obvious
Also, the compression ratio is 1.77:1 and I want to take this higher if possible.
Thanks in advance
Thanks in advance
