AVS › AVS Forum › HDTV › HDTV Recorders › Cox Cable - whole Home DVR Cisco
Cox Cable - whole Home DVR Cisco - Page 22
post #631 of 708
Originally Posted by Bryan_CoxPHX View Post
I asked the Cox Facebook support team to verify this and they they came back and said neither was true? Seems odd, so since you have had your set-up a week now can you confirm both the 500GB and eSATA is working as expected.
http://www.facebook.com/CoxArizona/posts/10151196925216220
Originally Posted by sammycasey17 View Post
Any Updates to this? Is Cox now allowing 500gb and eSata to work? Thanks
Bryan, I apologize for not responding back in Oct when you orginally posted your question. Somehow I didn't see it until Sammy posted his question above. I'm not sure what the Cox Facebook support team has to say, but I definitely have 1368GB of disk space to record on. The internal drive still shows 465GB total. My DVR has quite a bit of content recorded at this point, and I'm pretty sure I'm way over 160GB. I can definitely say it's working for me. I suppose I could post a picture of the screen to show it.
Sammy: All I can say is give it a try and see what you get. When I picked up this box, I went to the Cox store on Pima in North Scottsdale. I was expecting to only see the 160GB when I went to channel 1999, but was pleasantly surprised by the amount shown.
The DVR seems pretty stable with the external drive. The only "weirdness" I've noticed is that sometimes there is a 3-5 second delay after I Fast Forward through a commercial. The box will stop and start playing when I press the Play button, but if I try to hit REW or Skip Back, it takes 3-5 seconds before the command is executed. The recording keeps playing from where the Play button was pressed, and the OSD shows that it's still Fast Forwarding. i.e. >>> on the status bar, even though it's not. The odd thing is that it doesn't do it for every recording. Only some of them. I haven't figured out what common factor there is between the recordings that exhibit this.
Good luck,
Dave
post #632 of 708
As a part of my Epson 3020 install has been the effort to get video, specially 3D.
And as a part of my efforts has been to get off cable and more on to the internet.
I talked with Cox and CenturyLink about phone and internet service, Cox will cost me $95.00 for around 20 to 30 MB, Centurylink will sell me 20 MB fore $69.95 or 40MB at $74.95.
With a 5 year price lock.
A small saving, but with Cox's retaliatory attitude, IE IF I leave I lose a couple of grandfather deals and how last time they put in a internet slowing filter to block my possible stealing TV and even cut the wires ..(all proved when I had the TV system turned back on..) I get the feeling I will need to cut cable total out.
Has anyone done this? And if so how was DSL??
Just found a new test with different speed rates..Tested my speed:
Down load @ 29.5Mbps and uploaded @9.14 Mbps on cable
Now I can compare at the same rates...
Looks like I need 40Mbps DSL to match/beat my current Cable rates.
Rich
post #633 of 708
Good luck on that. You are going to have live right next to a CO with perfect copper for a DSL speed like that.
Edited by kingpcgeek - 1/21/13 at 4:31pm
post #634 of 708
From Dave Zatz: New Cox/Cisco Guide Shows Promise; Little Magic
http://www.zatznotfunny.com/2013-01/new-coxcisco-guide-shows-promise-reveals-kinks/#
"Cox says it will launch a new IP video gateway – six tuners, 2TB of storage – from Cisco in the first quarter of this year, and presumably that will facilitate the transfer of content between TV STB and mobile devices."
Cisco Explorer 9800 Multi-Screen Gateway Series - 6 Tuner DVR
http://www.cisco.com/en/US/prod/collateral/video/ps11488/ps12334/ps12291/9800_multi-screen.pdf
post #635 of 708
Coming to a Cox home near you in late 2014 at the earliest. Anyone want to take bets?
post #636 of 708
Based on what I was just looking at, I'll take that bet in a heartbeat.
post #637 of 708
I upgraded my 2 Whole Home DVR boxes to Cisco 8742 HDC's today. They come with 1TB inside as opposed to the 500GB in the initial Whole Home DVR's. It's helps to be an employee. smile.gif
post #638 of 708
Any other differences besides the increased storage space? Are they any more responsive to user commands?
post #639 of 708
Where are the 6 Tuner Cisco 9800s?
post #640 of 708
It does seem a little zippier. I also like the smaller footprint too.
From what I've been told, the end of 1st quarter.
post #641 of 708
Smaller receiver & larger time display.
post #642 of 708
Does the 98xx employ the standard 38MHz IR remote circuit, or does it use the 57MHZ IR? Its accessory list shows the 1004648 (IRE 5712M) IR extender, which is supposedly the 57MHz model, but I cannot confirm that these were ever manufactured. Indeed, the 8642HDC DVR also specifies the IRE5712 model, but vendors swear that the supposedly 38MHz IRE3812 works great with the 8642HDC. One vendor told me that the IRE3812 was made as a dual frequency model.
Any info?
post #643 of 708
To clarify the evolution of boxes. The Cisco 8642 box with a 500GB HD is end-of-life for manufacture by Cisco as of 12/31/12. The replacement is the 8742 that has 1TB HD. Both these boxes have the 1GHZ tuner and MoCA capability, independent of software. These boxes are just the newer year model over the 8300 series developed by Scientific Atlanta, prior to acquisition by Cisco. This means that they can have the old software, ROVI, or the new TRIO(Advance TV Plus) software. The new 9842 box is part of the VideoScape platform that was developed by Cisco.
Cox is a US launch partner for the Videoscape platform. This new box will have all the said specs from above that people want, the larger HD and tuning 6 shows at once. Its meant to also act as a headend for in-your-house conversion from the QAM(cable) to IP(internet) format of video so that other devices can access the media. This means that by using DLNA protocols on MoCA, you could view content on your DVR from devices connected to your house network. The goal is to move the process of video conversion into the home so that you iPad/tablet/phone gets its video from the box, rather than the data on your internet connection. I don't know of the extent to which Cox will allow the capability, but understand that this whole platform is the in-between step for the long term conversion to IP from the plant video.
post #644 of 708
So do you have to have this box to be able to access ondemand via IPAD?
post #645 of 708
Three questions:
1) When will the 9842 be available to Cox customers?
2) Is the 9842's IR at 57MHz like the 8642, or is it 38MHz like earlier boxes?
3) Do you have any information regarding availability of IR extenders IRE3812M or IRE5712M?
post #646 of 708
....... but understand that this whole platform is the in-between step for the long term conversion to IP from the plant video.
What is Cox's plan for supporting Retail CableCARD devices, in this conversion from QAM to IP video delivery?
Also, are you part of the Cox Social Media team?
post #647 of 708
Does the Trio DVR software have the ability to "automatically" record the next airing of a program when there is a conflict with the first airing, like the TiVo does?
post #648 of 708
No solid date yet on the 9842 for customers, but the target is 1st/2nd quarter.
No info on IR receivers for the 9842.
No info has been put out about CableCards for IP delivery. We aren't quite that close that we have released details on all items.
I'm part of the Social Team but I don't think Pastelero79 is. He is a solutions specialist.
Next airing is not in the current software.
post #649 of 708
Thanks, That is one of the best features of a TiVo, I would assume that is probably a TiVo patented feature, but if not Cox should definitely add it to Trio, especially with the current DVRs limited to 2-tuners. Having a 4-tuner TiVo has mostly eliminated conflicts, but they still happen.
post #650 of 708
It's actually on the request list.
post #651 of 708
One feature that is NEEDED - especially in these days of 1TB and 2TB HDDs in DVRs - is the ability to transfer stored programming from a DVR that the cable company is replacing to its replacement. I mean, what good is a 2TB HDD when 750MB of unwatched programming is lost when your DVR with a "glitch" is replaced? Maybe Cisco could help with this.
post #652 of 708
I know official support for externals will launch soon. Maybe that will take care of that.
post #653 of 708
Highly doubtful. You still lose the data on the internal drive. The data stored on the external drive will be encrypted with an encryption key stored on the main device. Without that key the data on the external drive is a bunch OF 0'S AND 1'S.
post #654 of 708
NO IT WILL NOT!!! The external hard drive is formatted by the box and tied to it totally: lost the box lose ALL DRIVES!!!!!
LOSE ALL RECORDINGS!!!
With a home made DVR that is NOT a problem.
Rich
post #655 of 708
One feature that should also be on the request list is a "Conflict Queue" or Missed Recording Queue, where missed recordings are placed in a menu that automatically link you to the OnDemand offering of the episode.
post #656 of 708
If the missed recording is even available as VOD. Twice my DVR failed to record "Person of Interest", which CBS chose to withhold from Cox's VOD lineup. mad.gif
post #657 of 708
A box failure and finding out that a few of our loved shows were in the same place, not on VOD and not on the networks own web site that caused me to dig in and find out how I could back up these shows.
I considered getting Direct TV again as a second system but they cost and again if something happens to the system your SOL.
That led me to consider converting to a Computer DVR.
It did turn out a little more complex that I had hoped, and after a few teething problems I have two Computer DVRs in our main viewing room and will put one TVIO in my wifes bedroom.
I also figured out I was paying $150.00 a month to record local TV Networks, which with the computer DVR is FREE Over The Air.
So I am working on dropping cable and going totally to OTA and Internet.
Rich
post #658 of 708
One feature I would love to see is the consolidation of the SD and HD channels in the guide. DirecTV has been doing this for years. If there is an HD equivalent of an SD channel, the DiecTV guide only shows the HD version. Even better, it automatically maps the HD channel to the standard channel. It's nice to simply select channel 8 and get the HD version automatically. I see no reason why Cox or Trio can't do this same thing.
post #659 of 708
Well, you already can make your program guide HD only, and have the option of going from the SD to the HD version of a channel simply by pressing one button. I guess those with 4:3 sets who DON'T have HD wouldn't like going to the HD version automatically.
post #660 of 708
True...But if I make the guide HD only, then I miss all SD-only channels. Not the same thing.
DirecTV only includes this feature on the HD settop. On top of that, this behavior, while the default, can be turned off in the settings. The SD settops only tune in the SD version of the channels so those with an older tube TV will not have a problem.
  Back to Forum: HDTV Recorders
