AVS › AVS Forum › HDTV › HDTV Recorders › Cox Cable - whole Home DVR Cisco
Cox Cable - whole Home DVR Cisco - Page 25
post #721 of 879
I don't see why it wouldn't. Works just like Google TV.
post #722 of 879
Thank you - the Google TV craze (if there ever was one) passed me by so I don't know how Google TV/Cox Live TV integration works either, but I'll take you word for it.
Thanks again!
post #723 of 879
Thanks again!
Exactly. It passed everybody by, which is why Xbox doing the same exact thing is so puzzling.
Anywho, you plug your cable box HDMI into the Xbox, connect an IR blaster out of the Xbox to control your cable box. Then tell the Xbox to change the channel, it sends the command over IR to your cable box and shows the live TV feed on the screen. Sounds pretty worthless to me, but I never thought the ShamWow would catch on either, so what do I know. Maybe Google TV on an Xbox will be awesome.
post #724 of 879
I have a strange issue. Have 2 WHDVR and 2 clients. The dvrs are in the family room (FR) and bedroom (BR). The bedroom has the longest run. I can view programming on FR on BR DVR and both clients. If I record a program on the BR DVR and attempt to view it on other three devices I get an error message to call customer service (CS) and give them code 2.1.2.2. It is viewable on BR DVR since it is recorded on that one. Called CS and they went through the reboot process on all devices and finally they are sending a tech for a home visit. Tried to get the tech that installed originally since don't want to have to walk a new tech through system. They said they could not send original tech just a random one even though I was will to wait. AM in Gainesville FL. Like system except for this issue. Any suggestions for fixing system and also getting same tech.
post #725 of 879
Removed by user
Edited by AUThach06 - 10/18/13 at 7:08am
post #726 of 879
Originally Posted by AUThach06 View Post
You are correct that Rovi owns the passport guide but Cox doesn't get it's guide data from Rovi. The guide data is from TMS for all video products that cox offers. They won't be a perfect match due to memory limitations on the Rovi hardware but ALL guide data is sourced from TMS.
It's Motorola and SA/Cisco hardware not Rovi hardware.
Rovi doesn't provide cable boxes
post #727 of 879
Source? Odd that the Rovi logo still appears in sections of the guide.
post #728 of 879
I believe he was referring to Rovi infested hardware.
post #729 of 879
Removed by user
Edited by AUThach06 - 10/18/13 at 7:07am
post #730 of 879
The Rovi guide runs on the lower end STB that have hardware limitations. The Rovi systems back end isn't shared with trio but they both leverage the TMS data feed.
Rovi is a patent house. They own patents for almost everything in the IPG space so their logo shows up all over the place. You could start to see it on Trio bc of the patents they own that were TV Guide patents. I can't say how I know but trust me I'm right on this. Just trying to clear it up for this forum.
Uh huh. The laughs I get from my MM contact at Cox make me quite "untrusting." Also odd then that the TMS logo shows up so much in Trio, but never in Passport. Not even a "Powered by TMS" reminder.
Edited by domino92024 - 6/7/13 at 1:41pm
post #731 of 879
Removed by user
post #732 of 879
I
Rovi owns owns the passport guide that is why you see the Rovi in the guide. The metadata provider is not mentioned in the the guide's
post #733 of 879
I
That must be why Tribune Media's "TMS" logo appears in the "Trio" program guide on Cox. TMS must own the Trio guide. NO WAIT...TMS has nothing to do with the "Trio" guide except for providing the data. Odd that the TMS logo does not appear in the Passport guide, too (like Trio), if they provide the data. wink.gif
post #734 of 879
This was posted on the Cox Forum about the new 6 tuner DVR, which they now call 'Record 6 DVR' . Looks like it will be sooner than I expected. Looking forward to being available in New Orleans.
So the dates have been revised, and this is why I don't like quoting them.
Trio 2.1 is now in final testing in Escondido (San Diego) and Palos Verdes and with some employees. It should then launch marketwide in Orange County, Palos Verdes, Santa Barbara, and Oklahoma City on 6/27.
The Record 6 DVR then launches in Orange County, Palos Verdes, Santa Barbara, and Oklahoma City on 7/2.
And the biggest additional feature at launch will be a 2-terabyte hard drive, as opposed to the 1TB of the G7 DVR. I can't comment on anything else.
Kip K. - Cox Support Forums Moderator\
post #735 of 879
That's interesting news! I will add to it that Cox OKC is for the first time adding SDV channels on 6/27. I have a couple of TiVo boxes, so received notice from Cox that I needed to add SDV adapters, which Cox furnishes at no charge, in order to watch the new SDV channels. I have the adapters in hand but don't intend to hook them up and get them configured until after Cox OKC actually has SDV channels on line. Thus, I guess that the introduction of Cox's new 6 tuner DVR in OKC and the addition of SDV channels are related.
post #736 of 879
Recording problems, Cisco box with 90% unused recording time has twice failed to record HD golf . The shows were lengthy about 5-6 hours, also any additional scheduled recordings during that time period were also deleted with an error message stating the recording was in conflict with a high priority recording. I've reset the box twice, once after the first failure to record and then again after the second failure. According to the remaining space bar I've never exceeded more than 25% of the available memory so It's not a question of available memory. Have yet to call Cox, thought i'd try here first.
post #737 of 879
Which Cisco model? Which DVR firmware? (Trio, Navigator, Passport, etc.)
post #738 of 879
Nice, can't wait. Even during the lowball Summer programming I'm still running into daily conflicts with the 2-tuner nightmare on most days...
post #739 of 879
Cisco 8640 new model with Trio about 2-3 months old. I like the new Cisco big improvement over the Motorola. The only bugs seem to involve recording which may be fixed with the new update in late June.
post #740 of 879
I sure hope you mean Cisco 8642HDC. I didn't think Cox was offering the 8640.
As far as your problem goes, what golf programs were 5-6 hours? I've never tried recording a 6-hour program on my 8642HDC/Trio. Maybe I'll try the British Open.
I did unsuccessfully try a 5-6 hour recording with my old 8240HDC/Passport. You might try breaking it up into successive 2-3 hour manually programmed recordings.
post #741 of 879
It's one of these I'm not sure which:
http://www.cisco.com/web/consumer/support/userguides2/4026881_A.pdf
The Golf match was the US Open last week. I know the French Open Tennis had three and maybe four hours segments. I'm going to try Wimbledon and see what happens but anything over three hours is questionable especially in high-broadcast rate HD.
post #742 of 879
Where does Cox use Navigator?
post #743 of 879
The actual model number is on the top-right corner of the front panel. I don't think the 8640HDC has the 500 GB HDD option, or MoCA.
Edited by domino92024 - 6/23/13 at 12:23pm
post #744 of 879
How about this....
Cox Targets Cord-Cutters With Internet TV Test in Southern California
http://variety.com/2013/digital/news/cox-targets-cord-cutters-with-internet-tv-test-in-southern-california-exclusive-1200503094/
post #745 of 879
FYI, for those interested, here is some new info about the new 6 tuner DVR that was posted on the Cox Forum site. Can't wait to get mine:
Domino
msmorgan69
Do you know when "soon" will be exactly? And other then the increased storage space, what other benefits will these have compared to the whole home dvr?
Exactly? No, as I don't work for Cox Phoenix. How does the first week in August sound? A lot depends on the success of the rollouts in earlier areas (OKC, SD, etc.) As far as benefits beside the 2TB HDD...6 tuners instead of 2, faster/smoother operation due to more RAM and faster CPUs, architecture that will support future platforms....did I mention SIX tuners?
Spot-on. Personally, I hate posting dates. I know that every time I post a date the ghost of Ed Murphy is going to come beat the tar out of me...
The Trio 2.1 software that backs the new box should be rolled out everywhere by 7/30. That includes some much-awaited bugfixes, and is supposed to increase access speed of some features like channel changes and DVR listings (even in older models). It also lays the groundwork for future enhancements (that are basically open secrets but I'm still not going to talk about yet ).
Tentative date for the launch to be completed in all areas is 8/5. The first half of the launch was all California, all Oklahoma, Kansas-Arkansas, and Nebraska-Idaho, and is supposed to be completed by tomorrow. The second half is everywhere else and is supposed to be done 8/5.
post #746 of 879
Cox is currently installing the new CIsco 9800 host and client box at my house. I will post shortly with my impressions!
post #747 of 879
The new units are quite a bit faster than the 8742HDC. This is especially noticeable when using On Demand. Of course the 6 tuners and 2TB's of storage are both very nice to have. I never worry about recording conflicts anymore!
post #748 of 879
Stolen from S.D. HDTV Forum:
Cox’s motto: “HD is FREE!” And their fine print always reads “Cox Advanced TV
(formerly Digital Cable) and paid subscription to Digital HBO, Cinemax, Starz,
and/or Showtime required for respective premium HD channels. Other HD channels
require subscription to Cox Advanced TV and service Pak with the standard
version of the channel.” *Oh, really*?
Cox’s “Plus Pak” contains 39 channels, all HD. 2/3 of those HD channels have SD
versions in various tiers or “Paks.” Yet Cox charges extra for access to those
HD channels. I get the SD version of the DIY network, BTN and the PAC-12 Net on
the “Sports & Information Pak” yet I must pay extra for the HD channels,
contrary to Cox’s stated policy. I get The Cooking Channel in SD in “Variety
Pak”, but not the HD version since it is in the “Plus Pak.” I get the SD
versions of 16 of the “Plus Pak” channels, yet must pay for the HD versions.
And WHY does this “Plus Pak” price vary depending on which DVR you have? Do you
have a TiVo or HTPC? Then, the “Plus Pak” is FREE! Have a Cisco 8642HDC or
8742HDC WHDVR? Then it’s $5/month for the “Plus Pak.” Have the new 6-tuner Cisco
9865HDC WHDVR? Then the same “Plus Pak” is $10/month. Why, Cox? Why? That’s like
selling a bag of potatoes for FREE to redheads, for $5 to blondes, and for $10
to brunettes.
Why, Cox? Why?
post #749 of 879
I was told by a Cox employee that I am acquaintances with that a recent software update to the Trio (WHDVR) has issues with tuning certain stations. For me, it seems to be HBO (810) Food Network (740) and a few others. It was explained to me that it mainly happens when switching from SD to HD, but since I almost NEVER travel to SD land, that can't be the only thing.
Has anyone else noticed this? He initially had scheduled a truck roll for Friday, but cancelled it when he found this (and the fact that the Tulsa area Cox techs are more busy right now with the storm cleanup).
post #750 of 879
Anyone know if it is possible to buy one of these boxes? $20 / mo. to rent one is a bit steep.
  Back to Forum: HDTV Recorders
