AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › The Bridge on the River Kwai Blu-ray vs DVD vs HDTV Comparison
post #1 of 12
Blu-ray | DVD from Blu-ray set | HDTV
The set came with a DVD also from the new master so thought I'd throw that in the mix. The 2000 DVD will obviously look similar to the HDTV since they are both are from the old master.
The Blu-ray has pretty much perfect mastering (not that I'd expect any less from Grover Crisp's team). Since this is a 4K scan from the negative with no filtering, all image quality issues are in the original photography.
Only negative:
No trailer or paper insert announcing Lawrence of Arabia Blu.
post #2 of 12
Thanks for posting these! I am really looking forward to seeing this on Blu-ray this week.
post #3 of 12
The HDTV version holds up pretty well.
post #4 of 12
The HDTV version looks excellent and not much different from the Blu-Ray with regard to texture and resolution which is a rare sight.
If I had to guess I'd say they go back to the same master, even the framing is almost identical.
Not that this changes the fact that I will get the Blu-Ray
post #5 of 12
Unless Comcast is your provider.
post #6 of 12
The Blu-ray is from a NEW master and was scanned at 4K.
post #7 of 12
Must buy BD!
post #8 of 12
Yeah, check out how much finer the grain is compared to the HDTV cap. I don't think that's all down to compression.
Originally Posted by El Paso Times View Post
"River Kwai" has been restored twice before, Crisp said, but this is the first time it's been done from the original camera negatives using "all these digital tools that allow us to fix things we couldn't do before." He said it's the second restoration -- "Dr. Strangelove" was the first -- on which Sony has used high-resolution digital technology, called 4K workflow.
"We scanned the original negatives at a high resolution and have been working to correct all the flaws in the film, like removing dirt or scratches or, in the case of this film, there were a lot of camera problems when it was actually shot," Crisp said. He noted that the film at times "jumps slightly" and had color registration problems.
Most of the corrections and changes won't be noticeable to the average viewer. But they are to film restorers like Crisp, which is one reason he's flying here to see "River Kwai" on the Plaza's 45-foot-wide screen. Crisp said he's never seen it on a big screen. He's been watching the restoration efforts on an 8-foot-wide monitor.
"This is our passion here, this kind of work, and it's great to put out Blu-Rays and all of that," he said, "but actually restoring it and seeing it in a big theater with an audience, the way it should be, is like the ultimate performance."
post #9 of 12
Looks fantastic. Wish Sony's mastering folks could do Apocalypse Now
Can't wait to see what Sony can do with a 65mm source.
post #10 of 12
edit- whoops
Looks fantastic.
post #11 of 12
SO glad they sorted out the skin tones
http://img716.imageshack.us/img716/5346/kwai17tv.png
^That was never right
post #12 of 12
Stunning! Good job, Sony!
  Back to Forum: Blu-ray Software
