AVS › AVS Forum › Blu-ray & HD DVD › HDTV Software Media Discussion › A new Blu Ray feature?
post #1 of 4
During the last two weeks I have purchased about five new Blu Ray discs. Three out of the five had broken cases upon opening. The tabs that keep the case closed on two, the center spindle on another.
Is this a new trend? At $25.00 a movie I would expect at least as good a case as the old DVD case some of them 15 years old and more and still in great shape.
Maybe it is just my lack of luck!
post #2 of 4
dvds were available through late 1997 and on. you cant possibly have dvd cases older than 13 years
post #3 of 4
Several of my DVD cases over the years have been broken on receipt. The most maddening were the snappers, which were hard to replace.
post #4 of 4
The only ones I've gotten that way were when someone bought it. Copied it. Then returned it. I could tell by a slit in the plastic. I usually look for it now. Happened more on CD's.
  Back to Forum: HDTV Software Media Discussion
