I recently realized that I have 1 overloaded 15a 16/3 circuit (htpc,receiver,br player,dish receiver,power amp) totaling 2640 watts. The 2nd 16/3 15a circuit into my room has a dedicated projector outlet drawing only 290 max.
I have a simple option of transferring the dedicated pj line to a dedicated power amp line. This would create a load of 1500w max on the dedicated line, and 1430 (total) on the equipment line.
I've also been fighting a ground loop thats introduced through the pj hdmi ground when its plugged into the receiver. I'd like to try to address that while I'm reworking the electrical.
Could my ground loop be caused by the current unbalanced loads on the 2 circuits tied together by the hdmi ground?
I can also go to 12ga/20amp if that would be advised, but I'd like to avoid that if not necessary. The 2 breakers available are on top of each other in the sub panel, so I dont quite get where the loop is coming from.
I could sure use some advice on a new configuration. All wiring and breakers can be changed in both circuits if thats what it takes. Any help?
