I am not sure this is the right forum but there is not an SDTV forum
. So I want to ditch Comcast. Antenna web and Tv Fool say that I should be able to get everything I need with a set-top or attic antenna. I have three old analog devices with tuners (2xReplays and one CRT Tv). I assume that all of the signals coming through the air are going to be digital and need to be converted to analog- is this possible without using some sort of STB tuner thing? Can I just do in universally in-line (before the 3-way split) somehow so that all of those analog devices could operate as they normally did when comcast analog was coming through the tube? So that they could tune and change their own channels, etc.
If I have to get each device some sort of IR-blasting DTA box then I'll just upgrade to HD digital TV with a tuner and ditch the replays.
TIA.
. So I want to ditch Comcast. Antenna web and Tv Fool say that I should be able to get everything I need with a set-top or attic antenna. I have three old analog devices with tuners (2xReplays and one CRT Tv). I assume that all of the signals coming through the air are going to be digital and need to be converted to analog- is this possible without using some sort of STB tuner thing? Can I just do in universally in-line (before the 3-way split) somehow so that all of those analog devices could operate as they normally did when comcast analog was coming through the tube? So that they could tune and change their own channels, etc.If I have to get each device some sort of IR-blasting DTA box then I'll just upgrade to HD digital TV with a tuner and ditch the replays.
TIA.
