First of all, I hope this is the right place for this. I have a WD Live Plus that I absolutely LOVE! However, I'm getting annoyed at having to reset it every other day. I typically leave the video output setting to HDMI (auto) as I have it hooked up to an Onkyo SR-705 receiver which does not upconvert. HDMI out of the receiver to my Optoma EP719 projector which is 1080i/720p at 60hz, I believe.
The problem I'm having is that the WD Live doesn't seem to select the correct video output settings. The WD loading screen will display, then, nothing and I have to hit the reset button. I tried manually setting the video output to something like 1080i (50hz) or (60hz) to no avail. It will display fine for a few times, then the next day will have issues. I tried switching up with a couple of them with similar results. It's frustrating because then I have to go in and re-adjust all of my other settings as well.
I was going to post on the Western Digital forums, as they've been a good resource for info, but figured I'd start here first. Any thoughts?
