Hi,
I've been researching and reading the various threads, messages, and comments on what to do to get the correct 24Hz (23.976) signal out of an ATI HDMI connection.
So to get 23.976 Hz out of my ATI 5850 (CCC 10.9a), do I put it on 24Hz or 23Hz in CCC? I had it on 24Hz, but noticed a slight skip in the picture every so often. My worry is if the good ATI folks didn't know 24Hz is actually 23.976Hz in AV-land, why would 23Hz be 23.976 instead 23.000. I suppose I could try it, but the problem is that I'm running the signal through a DVDO Duo, so I'm worried that it sort of compensates and it is not easily discernible. (Ok, and I'm too lazy to rewire everything).
I'm hesitant to use ReClock, because based on my readings on this forum, it causes problems with Hi-Def Audio bitstreaming, which took me a long time to get working.
Can someone please put me out of my misery? And while we're at it, should I have the 1080i/60Hz on 1080i/59Hz because of the whole 59.96Hz thing?
Thanks in advance.
Cam
Thanks in advance.
Cam
