AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Epson 8350 Placement
post #1 of 3
I asked this in the owners thread, but it got buried and unanswered. Thanks for the help.
I have been trying to make sure I have the placement issues correct but it is turning out to be confusing.
Here is what I want to do: 100" diagonal screen, ceiling mounted projector, at 10' throw, dedicated room, no ambient light.
The 8350 user manual says: throw distance of 9.8 to 20.9 feet will enable a 100" screen, and that the max shift from center of screen to bottom of screen is 71.7"
The throw distance calculator form the Epson website http://www.epson.com/alf_upload/land...ce-calculator/
says that at a 10' throw distance 100" screen with projector 24" from ceiling I will get a max shift of 72" from center of screen
The calculator at projector central
http://www.projectorcentral.com/Epso...ulator-pro.htm
says I can get a max 77" screen at 10' throw, but does not address shift. Big difference from the 100" that I want.
I would like to have the projector hang no more that 24" from the ceiling. This puts the lens roughly at 96". With a max shift of 72" (from Epson calculator) that ables me to shift to 24" from the floor. I want to set the screen at 28" from the floor. Is this correct?
Brian
post #2 of 3
I'm pretty sure you didn't use the projector central tool very well. I just tried it, and there's no problem doing 100" from 10'.
Make sure you put in the screen size on the right, but use the throw distance adjustment on the top left. That keeps both constant and adjusts the zoom once you have "placed" the pj the right distance you want it to be from the screen; otherwise it keeps a constant zoom (I think) and links the throw distance with the screen size, i.e. as you decrease one you also decrease the other.
post #3 of 3
Yep, I missed fixing the throw range and then adjusting the diagonal range. Thanks!
Any help with my math for the vertical fixed placement and used of vertical placement is still appreciated.
Brian
