AVS › AVS Forum › Audio › Home Theater In A Box › Sony HTSS360 Bypass volume limit
post #1 of 3
Hello Forum
I was wondering if there was a way to bypass the volume limiter on my sony it only goes up to 40 and it doesnt get loud enough for me im not worrying about blowing my speakers i got good extra warrenty.
Thanks Fudd
post #2 of 3
Originally Posted by fudd664 View Post
Hello Forum
Thanks Fudd
are you sure it goes higher ? check the manual .. it should say in there if there is a way. Also what are your speaker levels ? I think if there set higher the max volume is lowered
post #3 of 3
There is a volume limiter setting for the HDMI inputs I believe. You can change this setting in the menu. Though as noted above you may actually be at the system's maximum level...
  Back to Forum: Home Theater In A Box
