AVS › AVS Forum › Other Areas of Interest › Camcorders › Panasonic HDC-TM700
Panasonic HDC-TM700
post #1 of 3
I am thinking of buying this camcorder. Can the video be downloaded to a computer and then to a DVD? Can it be done now or is this in the future. Would I be better off buying a camcorder that records directly to DVD?
DaveOls
post #2 of 3
Get the TM700 and Edius Neo Booster.
You will be very happy.
post #3 of 3
Another option if you really want standard DVD from a high def camcorder (for some reason..) is Panasonic's VW-BN2 external DVD burner. Apparently it can also burn AVCHD 1080i clips if you so choose.
  Back to Forum: Camcorders
