AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › The Official HSU VTF-15H Thread
The Official HSU VTF-15H Thread - Page 83
post #2461 of 3944
Originally Posted by chaneyj1 View Post
Maybe someone can help me out, I finally ordered a VTF-15h, waited for it to come off backorder, waited for it to get delivered, and now I am not happy with it. Just not what I thought it would be. I must be doing something wrong. Here are my specs on my room and speakers.
Onyko TX-SR707
Fronts: PSB B6
Center: PSB C5
Rears and surrounds: PSB in-walls
I have tried the sub in both front corners of the room and every tuning option available.
Room is 18' x 29' x 8', the tv is on one of the 18' walls.
I ran Audyssey with 1 port open, EQ1 and Q=0.7 and gain at 9'oclock.
After Audyssey runs and I play music and movies, there is almost no bass. Audyssey sets my crossovers at 40hz, so I moved them up to 80hz. I have tried increasing the level cal on the Onkyo from -4.0 to 0, and increasing the volume on the sub. Both do make it louder, but I just can't get it to sound good. Not what I would expect for $1k. Everyone seems to love these, so I know I am just doing something wrong or my room placement is just horrible.
The bass will get deep, but when it hits it doesn't sound great. I can't think of a good word for it, the wife said it sounds loose. I described it as a whomp sound. I know, that is horrible.
Does anyone have any ideas on placement or setup?
Can you post a detailed drawing of your room? Are there permanent openings that lead to other areas? If so, sketch in the adjoining rooms as well. Indicate where you sit in that space. Can you show us the response of the sub in your room?
post #2462 of 3944
Onyko TX-SR707
Fronts: PSB B6
Center: PSB C5
Until the DR. has a look at your room drawing out of curiosity have you tried it with Audyssey turned off and if you want it tight with slam try both ports open EQ 2 and Q=.3 also you may have to flip the phase switch it will be in the right configuration when bass seems more pronounced.
post #2463 of 3944
Also check to see if Audyssey Dynamic Volume is turned on and try turning it off if it is enabled. I would also make sure all speakers are set to small and double bass in the Onkyo is turned off.
What movies are you demoing this with? Not all content has tons of LFE.
I would also consider the sub crawl test. You could just be sitting in a null spot, but the good Dr will take care of you.
post #2464 of 3944
Originally Posted by ack_bk View Post
So what is the first movie on the list
The Cowboys and Aliens blu-ray from Blockbuster Online is still sitting on my counter so that might be it.
There will be dubstep played prior to any movies however. A lot.
post #2465 of 3944
First, thanks for responding so quickly, I also want to emphasize that I have no doubts that this sub will shake my house, I just have to get it setup correctly.
Attached is my quick room layout.
I will try other people's suggestions tomorrow, kids are sleeping now
Thanks everyone,
Jeremie
post #2466 of 3944
I hope those seats are not at the 14 or 15 foot mark center of the room is usually a null for bass.
post #2467 of 3944
I noticed that too. OP, that sub crawl test should be pretty revealing if you are sitting in a giant null. If you have any ability to move the couch a few feet closer or further from the center of the room it should help.
post #2468 of 3944
Ok, I will try that tomorrow. This is the first I have heard of a center dead spot.
Also would beside the couch be an option for the sub? The side farthest from the tv.
Jeremie
post #2469 of 3944
Jeremie
It should. When you are sitting in a null spot outside of adding a second subwoofer to smooth out response near field placement is about the only other option you have outside of moving the couch.
post #2470 of 3944
I would do a sub crawl test with the sub sitting on the couch. If you cant find a good spot as is, try to move the couch with the sub on it until u find abgood spot for your subwoofer. This made day and night for me!
post #2471 of 3944
So I put the sub on the couch and walk around and find the spot that sounds the best and then put the sub there? Ok. I'll look into that after I see what the good Dr. says.
Jeremie
post #2472 of 3944
Jeremie
For reference:
http://www.audioholics.com/tweaks/sp...ofer-placement
Your other option is to get a meter and use REW.
post #2473 of 3944
Thanks everyone,
Jeremie
What is on the other side of the French doors? One problem is you are sitting in the middle of the length of your room. Deep bass null. Any possibility of moving the seats closer to the TV? If you can be about 10 ft from the front wall, that would be better than in the middle. Also, try opening the French doors. That can give you better deep bass as well.
Is placing the sub directly behind the center seat an option?
Yes, sub crawling is a great approach. Try the crawling with the French doors closed and with them open.
post #2474 of 3944
The other side of the french doors is just stairs, a set leading up and one leading down. So those doors can stay open if it will help.
I really want to avoid moving the seats closer if I can. I will try the sub crawl tonight and see what I find. Also, behind the seats might be an option.
With my size room and knowing where my seats are, what settings would be best for me? We use that room for about 50% tv, 30% movies, and 20% music.
Thanks again,
Jeremie
post #2475 of 3944
Also, the manual states that I don't need to use a y-adapter but it doesn't say to use the left or right input. I assume this means it does not matter? Just double checking everything I can think of.
Jeremie
post #2476 of 3944
Jeremie
It really should not matter since the .1 signal from the AVR is a mono signal of all combined bass at the crossover point and the amp in the sub is a mono amp and as for the y adapter I don't use them.
post #2477 of 3944
Thanks again,
Jeremie
I would go for two ports open, EQ2, Q=0.3 and place it directly behind your favorite chair. Leave the French doors open if you cannot move the chairs forward. By having the sub close to you, you increase the direct to reflected sound ratio. Bass gets tighter and punchier.
The sub crawl test is best if you can do measurements. Place the sub at the listening chair so the woofer is at ear level. Put the mic where the woofer would be at the various locations where you can put the sub.
post #2478 of 3944
Onyko TX-SR707
Fronts: PSB B6
Center: PSB C5
I received my 15H on Friday and pretty much have the same complaint. It's just not what I thought it was going to be and am dissapointed so far.
My first question is about returns. I called down to HSU to check and it seems as though I have to pay return shipping which is fine, but I also get nailed for the $140 shipping charge to me initially. So for my 1 week in home trial this is costing me around $250???? That seems absurd and not what I was lead to beleieve when I spoke to HSU initially. I was told I'd only be charged return shipping and refunded the difference of what I paid. HSU charged me $140 to ship to me. I checked Fed-ex and my cost is around shipped should be $90 with $900 insurance so that shipping price to me was already inflated by $50! I was going to ask about shipping cost to me whether I returned it or not, just seems excessive...... I'm sure they have a commercial acct. with Fed ex and would cost them even less.
I was torn between HSU and SVS initially. SVS charges ONLY return shipping, their PB12Plus ships freight on a pallet and shipping weight 157lbs and $130 total shipping, so I'd be refunded all except the $130. Thier 12-NSD is $50 shipped and only minus $50 I'd be refunded and so on. I probably would not have even considered HSU over SVS if I knew I be out $250 for the trial (that $250 difference would have paid for my PB12-plus!). I'm hoping the info the gentleman at HSU gave me was wrong as now it's very unsettling.....
With all that being said I really want to make this sub work for me. It's in the best location as far as the sub crawl tests I've done with this and ALL my other subs over the years. I've had 4 different subs literally in this EXACT same spot so It's not a location issue. I know we need a lot of information room size, placement, seating, amp, corssover setting, sub setings etc..
I've ran YPAO in EQ1 Q=.7 LFE to the left sub input (LFE input) crossover on sub set to out, gain at 9 Oclock (had to move up to about 11:30 to get acceptable bass and have amp auto set to around -7.5). For movies I need to run the sub HOT at +6.5 to +8.5 for movies and +10 for music. This is with the reciever at -18db to -10 depending on what I'm listening to. Tried all the settings and wound up at as suggested EQ2 Q=.3 speakers set to small, sub set to yes, double bass off, amp X-over 80hz Phase 0*. I set up at EQ2 Q=.3 because that give me a little more full range, it stinks there's such a compromise and have to choose more between full range or low range, I didn't realize that at my initial purchase vs say others 18-150HZ +-3db
I just don't have the midbass I need or want. It's kind of tight but not punchy and not very existant comapred to my BIC H100. The H100 feels like a nice tight punch in the chest which I don't get with the 15H. It's definitely lacking in music for full range, especially country so I don't know what gives....... I installed EQ room Wizard last night and getting ready to go buy a 33-2055 SPL meter to try and get some measurements, which HSU said to call back with info to see if they can determine the issue and resolve it. It has a lot of lower bass but just a diferent sound than I thought. It's probably broke in by now since Friday, but IDK for sure. I've been debating posting this since Friday. I called HSU first to find out about shipping and I'm not happy with what I was told.
I don't want to have to return this sub, I want to make it work. It seems as though most people like it. The thing will be a hassle to send back and is HUGE. But if I have to and wind up losing around $250 for the in home trial I'm not going to be a happy camper!!!
post #2479 of 3944
There has to be something wrong the H100 is a decent sub but no where close to the VTF. Have you tried it with no room correction?
post #2480 of 3944
Onyko TX-SR707
Fronts: PSB B6
Center: PSB C5
30' is a long room - you may want to try a near field position. Meaning that assuming your seating position is somewhere in the middle of that 30' - try placing the sub in a "end table" type position near the sofa. But still near the wall.
post #2481 of 3944
If you walk around the room is the bass stronger in some places than others. I'm wondering if you are sitting in a null?
post #2482 of 3944
I would not return it until you have exhausted your troubleshooting. As others have said, something is really wrong if you BIC 100 has more midbass than your 15H. If you look at the Audioholics CEA measurements, the Hsu is rated 5-8db higher across the board from a Bic PL-200 which is a step up from a H-100. It would take about 3 H-100's to equal the output of a 15H.
I have heard that YPAO can really mess with subwoofers. I would try turning it off and using an SPL meter or even just manual adjustment for now. Also, are you trying to integrate the 15H with another subwoofer, or just by itself?
The eD A2-300 and PA-150 subs I owned were both considerably superior to a BIC100, and the 15H is superior to both of those subs combined. And my room is longer than yours. Just make sure you are not sitting in a null, and the crawl test and REW should tell you.
As for return shipping, it says right on their website that the buyer is responsible for shipping costs. It does not just say return shipping. Something you have to watch for when you buy.
http://www.hsuresearch.com/faq.html#3
post #2483 of 3944
Here are two recent posts from the Epik thread where they had a similar experience using YPAO:
http://www.avsforum.com/avs-vb/showp...ostcount=18143
http://www.avsforum.com/avs-vb/showp...ostcount=18144
Sounds like disabling YPAO resulted in a noticeable difference.
post #2484 of 3944
Sucks to hear that. How big is that room and does it open up or have door ways to any other rooms?? How big is the floor its on?? Did you try to hook up the sub directly to the amp/receiver??
post #2485 of 3944
At 11:30 on the sub it should be trying to run you out of the room.
On the AVR what is the sub out most I dealt with are from -10 to +10 and the norm
is -5 with the sub set from 8:30 to 9 o'clock.
post #2486 of 3944
Sorry to hear that. Very strange. Not possible that it is worse than a H100 if it is working properly. Please post a drawing of your room. Indicate where you sit in that space, and where you put the sub. If you have openings that lead to other areas, sketch the adjoining rooms in as well.
post #2487 of 3944
This is sheer speculation on my part, but i'm wondering if Audyssey may be playing a role in all this. On my Pioneer SC-35 using MCACC(which doesn't do any correction on the subwoofer(please correct me if im wrong)). I went in afterward and set my speakers( BP 2006 W/built-in powered subwoofer) to small and the crossover to 80 hz. The subwoofer level on my Pioneer is set to zero. The sub(1 port open), EQ2 and Q at .3 with sub volume between 9-11 o'clock is absolutely outrageous with material containing substantial LFE.
post #2488 of 3944
It has a lot of lower bass but just a different sound than I thought. It's probably broke in by now since Friday, but IDK for sure. I've been debating posting this since Friday.
The H100 has a huge peak around 60 Hz with fast falling response above and below that. The sound of a flat subwoofer is very different from the H100. The fact that you are hearing a lot of lower bass sounds would make a lot of sense - that is the way it should be compared to the H100. Perhaps having a lot of low bass is not what you are looking for? The 15H has tons more low bass than the H100. An MBM would be more suitable if you are looking for lots of punchy bass without the low bass.
Try placing the sub as close to you as possible and set the sub to sealed mode, EQ2, Q=0.3. If you can, place it right behind your chair.
post #2489 of 3944
Thank you for the response, before we go any farther first thing I would like to ask is about the return shipping. So If I return this am I really out almost $250 just for the trial? I guess I wasn't aware of this costing near this much total. SVS (the other sub co. I was considering)is half that and their shipping weight is 157lbs shipped and they use Fed-ex freight which is more expensive and I'd only pay return shipping($130 loss to me total, or $50 lost for the NSD).
Why am I charged so much to ship to me when it probably cost HSU about half of what I actually paid to have it shipped? Buyer beware I guess huh???
I just wonder if all potential buyers are aware they risk losing $240 - upwards of $300 depending on their location for their 30 day satisfaction trial? This would have been an absolute deal breaker for me and very unsettling as returning is on my mind. If I have to return this and lose that much unfortunately HSU won't be a consideration for a repurchase of a sub unheard.
post #2490 of 3944
Is your seating position in the middle of the room? Also, is it a concrete floor?
Onyko TX-SR707
Fronts: PSB B6
Center: PSB C5
