Yes. Aud had set it at -2 t the receiver and I set it to 0. Also, my 15H is at around the 9 am position.
post #2521 of 3937
4/5/12 at 9:46am
. I'll consider trying to squeeze in nearfield next to couch in listening postition. This has been the worst place that I have placed all my subs over the years with no benefit room of gain whatsoever and sounds dull. Not only that it's so easy to localize the sub. The only benefit is I can physically feel the subs when facing the couch (which I'd do with a 2nd or 3rd sub just to feel more, kind of a cheap buttkicker so to say). I'm not sure I'll have enough room to fit the sub sideways facing the couch, if I do then the sub cable will be pushed against the wall and the grill of the sub will be pressed against the couch. Not sure if touching the couch would be too close?
My firmware is version 1.14 and thr most current on Yamah site is V2.05 but I hear it's all the way up to 2.11 i don't know if V2.05 would make any difference? Where are you located in AZ? I'm in Surprise. I'd love to hear how a properly set up system sounds.
