Originally Posted by saltysteven
I'm not doubt this monster for one second when it comes to movies but music is different. Let's say something with alot of bass like dance music. Its a constant bass beat. At the 9 position its way to much!!! Its just over powers the speakers and way to much exaggerated bass. Another question is should I have the enhanced button on or off?
Setting to 9 o'clock will certainly be too much! In our demo room, our 15H is set at 1/3 way up between minimum and 9 o'clock.
Also, if you want more mid bass, use the sub as an end table to your left as you look at your TV. Set the sub to two ports open, EQ2, Q=0.3.
Two are real and two just have the grills.
Each mic has the mic calibration file included in the included cd. If you ever get a new mic, one must remember to install the new file that comes with it. Another words, the software is married to each mic.
I never called you stupid or anyone else. Unless you have the latest Audyssey with XT32, the older versions, MultiXT and EQ2, could also mess up when EQing the low end and required additonal tweaking to get it right. You're quite the character.
