Originally Posted by dr_hsu
You should take out both port plugs. I think it will sound best with both ports open, EQ2, Q=0.3. Volume setting sound terribly high. With both ports open, you should not need to set the sub any higher than 9 o'clock. What is the sub out level on the receiver? Did you run any auto calibration?
With the new space, I would try the sub to the left of your equipment rack at the back as well. Will the preferred seat be the first row or second row?
I switched it to the settings you recommended and removed both plugs. Sub out level is 0db under tone controls if that's what you mean.
I haven't run audyssey as I believe it's a moot point since we are moving and my sub is not in an ideal location at all. Main listening position is front row center. I only have my fronts + center hooked up with the sub. My rears are boxed up for the move.
Update: Sounds better with new settings and using 8:30 position. Quite a difference for music.
Edited by Cobb28 - 12/13/12 at 5:04pm
